Fuel pump voltage
Old Jul 8, 2005 | 06:05 PM
Reelizmpro's Avatar
Default Fuel pump voltage
Fuel pump went out again, don't know what the **** is going on. It went out on me before, I patched up some wiring and it ran fine for a few months and now it's dead again. I measured 10.65v at the fuel pump connector under the storage bin. Is this enough for a Walbro pump?
Old Jul 8, 2005 | 06:08 PM
sam385's Avatar
Default Re: Fuel pump voltage (Reelizmpro)
should be 12V, no?
possible bad connection(s) or faulty main relay?
Old Jul 10, 2005 | 04:50 AM
StorminMatt's Avatar
Default Re: Fuel pump voltage (sam385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 &raquo;</TD></TR><TR><TD CLASS="quote">should be 12V, no?
possible bad connection(s) or faulty main relay?</TD></TR></TABLE>
You probably won't see 12V with the stock wiring. The fact of the matter is that Honda uses very small gauge wiring for the fuel pump. This, combined with the rather heavy current draw and the voltage drop at the relay is going to result in low voltage at the pump. The only way to increase voltage is to add a second relay of higher current carrying capacity and use larger wire to supply the pump.
Old Jul 10, 2005 | 06:33 AM
pyro_freak8's Avatar
yeah, i'd say set up a relay with a dedicated 12v since you're using a walbro
zippakilla
Feb 6, 2009 04:01 AM
datonefoo1
Feb 8, 2008 12:29 PM
94delsol6428
Dec 27, 2006 07:06 PM
RCSIVTEC
May 12, 2002 10:14 PM
