K-series: Castillo's 94.9mm crankshaft
Old Jul 8, 2005 | 06:00 PM
edo's Avatar
edo
Default K-series: Castillo's 94.9mm crankshaft
This crank was prepared in the same fashion as our 88mm and 105mm strokers by Castillo's Crankshaft Specialist. Again, Joe and Rudy modified a K24 99mm crank to the new 94.9 mm, 3.737" stroke. We opted to use a smaller rod journal diameter for this crank and went down to the 1.771" B-series size. This will reduce bearing speeds compared to the larger 1.890" K, F and H rod journal diameter on the two previous cranks. The 94.9mm crankshaft will be utilized in our 2415cc NA development motor.
-Ron
Old Jul 8, 2005 | 07:31 PM
WHTZ's Avatar
Default Re: K-series: Castillo's 94.9mm crankshaft (edo)
Old Jul 8, 2005 | 07:33 PM
Professor15's Avatar
niiice, is this the one with the 1.7 or something rod to stroke ratio?
Old Jul 8, 2005 | 07:38 PM
edo's Avatar
edo
Default Re: (drchulo)
1.668 r/s ratio for the 2415cc setup.
-Ron
Old Jul 8, 2005 | 07:41 PM
Default Re: (edo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edo &raquo;</TD></TR><TR><TD CLASS="quote">1.668 r/s ratio for the 2415cc setup.
-Ron</TD></TR></TABLE>nice, are you going to port the head aswell? and will you be running those ips-k10 cams?
Old Jul 8, 2005 | 09:27 PM
edo's Avatar
edo
we'll see what happens, right now stock cylinder head. We'll be testing all our NA cams in this motor.
-Ron
Old Jul 8, 2005 | 09:45 PM
CRXEE8's Avatar
Default Re: (edo)
Nice job... are all the K24A cranks alike or do you prefer the TSX one for an example?
Old Jul 8, 2005 | 10:09 PM
edo's Avatar
edo
Default Re: (CRXEE8)
We've used Accord/Element/CRV cranks so far, but not the TSX mainly because of availability and cost. It doesn't matter really, the prep is the same.
-Ron
Old Jul 8, 2005 | 10:25 PM
What is the advantage of having a lower bearing speed?
Old Jul 8, 2005 | 10:45 PM
gsrious's Avatar
higher revs my friend...
actually i think that with the less bearing speed, there is less wear and tear on the bearings. also with the 94.9mm stroke compared to the 99mm... that enables the reving to go higher...
edo's Avatar
edo
Reduced friction.
-Ron
Old Jul 9, 2005 | 08:17 AM
marcin's Avatar
Default Re: (edo)
just curious,
were the oiling holes for the rods/mains worked or did they come from the factory like that?
I forgot what the name is for the procedure, when you shape them like that.
thank you
m.
Old Jul 9, 2005 | 09:20 AM
edo's Avatar
edo
Default Re: (dvious hatchie)
Teardropped oil chamfers, standard race prep at Castillo's and doesn't come like that from the factory.
-Ron
hatchet_honda
Nov 6, 2009 08:26 AM
edo
24
Jul 15, 2008 05:43 PM
edo
14
Sep 4, 2005 05:23 PM
bigTom
Mar 19, 2002 06:18 PM
