Problem with DIY drop-in using K&N RU-2820 :(
Old Jul 8, 2005 | 04:38 PM
94integrals's Avatar
Default Intake Problem Solved :)
UPDATE: Problem SOLVED. Used hairdryer to heat up filter opening + elbow grease. Thanks 94DOHCGsr!
I read several posts about the DIY drop-in K&N filter setup and gave it a try.... The problem is that the RU-2820 filter won't fit up to the stock intake elbow on MY car since the opening on that is larger (about 3.25 inches external diameter) compared to the K&N filter's which is 3 inches (internal diameter). It is very frustrating after getting this far... Should I hack away at the K&N opening to make it bigger? Did yours fit right up? I have a 1994 Integra LS and all of the components were the same as when I got the car from the dealer in 94. I can't see Honda changing the specs on something like that.
Here are the directions I followed at BretQs site:
http://www.derestricted.net/it...x.htm
Here are pictures from BretQs 1994 GS-R site:
Here are pics from PatrickGSR94:
This is exactly what I am trying to do using the same filter the RU-2820. It doesn't make sense that the intake arm on a GS-R would be smaller (3 inches) than my LS (3.25 inches)... Here is a pic of the intake elbow. The diameter of that top opening on mine is 3.25 inches and because of that, the filter won't fit over it.
Modified by 94integrals at 8:46 PM 7/8/2005
Modified by 94integrals at 8:48 PM 7/8/2005
Modified by 94integrals at 8:55 PM 7/8/2005
Old Jul 8, 2005 | 05:03 PM
Evanmb44's Avatar
as long as the piping meets up to the end of the filter you should be fine....it doesnt have to seal inside the airbox
Old Jul 8, 2005 | 05:04 PM
94DOHCGsr's Avatar
Default Re: INTAKE PROBLEM with DIY drop-in using K&N RU-2820 :( (94integrals)
get a hair dryer and some vaseline. heat up the filter and apply some lube to it. Mine still needed some elbow grease but just keep at it. It will go eventually. NEVER give up. gl
Old Jul 8, 2005 | 05:13 PM
ROOROWNS's Avatar
BTW that is a pretty cool setup. Looks like the DSM filter. Good Luck
Sean
Default Re: INTAKE PROBLEM with DIY drop-in using K&N RU-2820 :( (94DOHCGsr)
94DOHCGsr: Thanks for the advice... I was surprised how well that hair dryer worked
Modified by 94integrals at 8:47 PM 7/8/2005
pawl
11
Jul 20, 2013 09:24 AM
slvrstns2000
Jun 7, 2006 09:25 AM
mx621
10
Jan 29, 2006 06:13 PM
SOFLSOL
Mar 5, 2004 11:29 AM
