How do you advance/ retard timing on a ZC motor?
Old Feb 15, 2002 | 09:14 AM
Speed_Ricer99's Avatar
Default How do you advance/ retard timing on a ZC motor?
It doesnt look like the distributer turns...
Old Feb 15, 2002 | 09:18 AM
Default Re: How do you advance/ retard timing on a ZC motor? (Speed_Ricer99)
Also, what is the acutal # for the ZC motor ????? Ive red different #s in differnt books.
Old Feb 15, 2002 | 09:26 AM
therealciviczc's Avatar
The distributer moves just like any other motor.
The ZC is just the ZC. Its the same thing as a D16A8 and A9 (I think that's the two numbers alhtough its been a long time).
Old Feb 15, 2002 | 11:12 AM
animatd's Avatar
Default Re: How do you advance/ retard timing on a ZC motor? (therealciviczc)
the distrubutor does turn
Old Feb 15, 2002 | 11:18 AM
Jesse H's Avatar
Default Re: How do you advance/ retard timing on a ZC motor? (animatd)
Did you try loosening the 3 bolts first?
*snicker*
Old Feb 15, 2002 | 11:42 AM
keithv's Avatar
Default Re: How do you advance/ retard timing on a ZC motor? (Jesse H)
*snicker*
if that was the "reason" why the dist. didn't turn, i think i might **** myself in laughter...
Old Feb 15, 2002 | 04:34 PM
daniel89civ's Avatar
may be you used your stock d15 distributor and you did the only one bolt thing and you can moved
you dont remember making a hole to fit the distributor
i have to check to check i think 89integra will fit and can be moved like anystock one
Old Feb 16, 2002 | 05:26 PM
Default Re: How do you advance/ retard timing on a ZC motor? (daniel89civ)
I atually Never took it off, it came as part of the ZC motor and I didnt touch it. I just looked at it and said "well, its not round, so it probibly doesnt rotate."
Thanks for all you info guys, Youve been a big part in saving me 1500$ over what the shop wanted to charge me for a motor replacement....
themex77
Jan 31, 2005 05:20 PM
DarkZachiel
10
Sep 2, 2002 10:09 AM
zc crx
11
May 26, 2002 10:05 PM
