Questions about Clutch's and Flywheel's
Old Jul 8, 2005 | 01:46 PM
90 Si Hatch's Avatar
Default Questions about Clutch's and Flywheel's
Ok here is the deal, I have a 97 D16Y8 and a 1991 Civic Si cable tranny. well i was looking on ebay at a clutch and flywheel combo and my question was, can i use the 1991 Clutch & Flywheel on my 97 motor. Thanks to whoever can help
Isaac-
Old Jul 8, 2005 | 01:47 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Questions about Clutch's and Flywheel's (90 Si Hatch)
clutch and fly for your tranny
Old Jul 8, 2005 | 01:48 PM
Default Re: Questions about Clutch's and Flywheel's (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">clutch and fly for your tranny</TD></TR></TABLE>
What do you mean?
Old Jul 8, 2005 | 01:49 PM
Ass$nyper's Avatar
you have a 91 cable tranny get clutch and fly for that
and yes it'll bolt to a 97 y8
Old Jul 8, 2005 | 01:51 PM
ok ok i gotcha now, Thanks man.
any one elses input?
Old Jul 8, 2005 | 02:36 PM
Mach69's Avatar
90-00 flywheels are practically identical. And clutches/pressure plates too, i think.
Pretend like you have a complete '91 si engine and transmission combo and buy the flywheel and clutch for that. It will bolt up to the Y8. You'll be fine.
Old Jul 8, 2005 | 07:44 PM
jlicrx's Avatar
Default Re: Questions about Clutch's and Flywheel's (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">90-00 flywheels are practically identical. And clutches/pressure plates too, i think.
Pretend like you have a complete '91 si engine and transmission combo and buy the flywheel and clutch for that. It will bolt up to the Y8. You'll be fine.</TD></TR></TABLE>
if you are buying a complete clutch kit, you want the 91 as throwout bearing is different on 92up
Old Jul 8, 2005 | 07:57 PM
Mach69's Avatar
Default Re: Questions about Clutch's and Flywheel's (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
if you are buying a complete clutch kit, you want the 91 as throwout bearing is different on 92up </TD></TR></TABLE>
Yup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote"> Pretend like you have a complete '91 si engine and transmission</TD></TR></TABLE>
Old Jul 8, 2005 | 11:21 PM
NastyHabitzCRX's Avatar
i use the 92-up flywheel and pressure plate since it is a little bigger then the 89-90 Si.
Old Jul 9, 2005 | 05:08 AM
Sikocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 Si Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Ok here is the deal, I have a 97 D16Y8 and a 1991 Civic Si cable tranny. well i was looking on ebay at a clutch and flywheel combo and my question was, can i use the 1991 Clutch & Flywheel on my 97 motor. Thanks to whoever can help
Isaac-</TD></TR></TABLE>
Simple answer is yes
Old Jul 9, 2005 | 06:18 AM
RACINTWEEK's Avatar
Default Re: (NastyHabitzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX &raquo;</TD></TR><TR><TD CLASS="quote">i use the 92-up flywheel and pressure plate since it is a little bigger then the 89-90 Si. </TD></TR></TABLE>
90-91 are teh same as 92-whatever d-series, its the 88-89 that are different
Old Jul 9, 2005 | 09:07 AM
Default Re: (RACINTWEEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">
Simple answer is yes </TD></TR></TABLE>
^^^^^^^^^^^^^^^^^^^^^^^^^^, This guy is great, Thats all i needed to know LOL. but thanks to everyone who helped!!!
Old Jul 9, 2005 | 10:19 AM
djsire's Avatar
Default Re: (90 Si Hatch)
not to jack this is on the same topic. i have an 89 crx si and i want to put a z6 in it should i use the z6 fly and cluth or the si fly and clutch
Old Jul 9, 2005 | 11:15 AM
Mach69's Avatar
Default Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">not to jack this is on the same topic. i have an 89 crx si and i want to put a z6 in it should i use the z6 fly and cluth or the si fly and clutch</TD></TR></TABLE>
Put the flywheel/clutch and pressure plate of the transmission. That of the 89 si.
I know that the '90-'91 clutch, flywheel and pressure plate work on the 89 si transmission (thats my setup). The 90-91 clutches are larger than the 88-89 clutches.
t-town_ep
10
Feb 8, 2012 06:17 AM
adam4lsu
Mar 26, 2007 07:31 PM
pinecone
Jun 22, 2006 05:27 PM
5thGenKing
Oct 28, 2004 06:57 AM
phatrick2332
10
Oct 11, 2003 02:36 PM
