apexi n1 Question
does anyone know if a 98+ n1 exhasut will go on a 97 integra GSR, i cant get it to go over the contorl arm for some reason. I have omin full race coilovers and the wheels dont drop wheni lift the car up and before i pull the control arm off to see if that will work, i just want to know if it will fit or not, thanks
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
why aren't your wheels dropping when you jack it up? you're using the jack points and not the control arm to jack it up right?
if you wheels don't drop any, something's up with your suspension...
i have omni race version, omni control arms, and hyper flex bushings, they just barely drop when you lift the car, so the axle back should fit, thanks i will take my control arm off and try
n1teg97ls
Oct 27, 2007 05:48 PM
DeDonDeRosa
Jan 22, 2003 04:10 PM
