FIrst Tech Post: DIY HEADUNIT cooling.
Old Jul 8, 2005 | 11:18 AM
needaimport's Avatar
Default FIrst Tech Post: DIY HEADUNIT cooling.
well i got an idea, and i got bored.............
this is a 92-95 civiv hatch, although im sure you can use my intructions on other apps.
ok anyways this is for some people who take long trips while listening to music, people with a badass headunit/system, or normal joes who are bored (me).
this is how to put a computer cooling fan under your headunit in a really coooool way.
Tools/materials:
1. a fan from an old comp, or get a new one (theyre only like $10)
2. dremel
3. drill
4. soldering iron or crimps
5. electric tape
6. boredom
7. time
8. a switch ($2-$5) <-- optional
1.take out the ash tray and cut off the metal reatainer. then dremel away the plastic that held the retainer in place.
2. drill a bunch of holes underneath for it to get air.
finished here but on a side note these holes were not enough. had i been able to find my cutting attachment for the dremel i would have just cut a gaint square to let nrestricated air get into it.
3. cut a hole for your switch if you're using one. i decided to go with it because i wanted to be able to turn it on and off just in case. you should know how to wire it to a switch.
tada!
4. zip tie the fan into the ashtray
5. bring the whole assembly into your car. note the holes on the metal plate, again if i had my cutting attachment, i would have cut a giant whole for free flowing.
6. splice the postive wire from the fan to the yellow wire (from tthe clip/harness that powers your cig lighter) and the negative into the black wire.
7. screw it back into place
8. check if your fan is still there.
9. check if it works
10. clean up your damn mess
11. go take a shower (its too hot outside not to sweat like a pig)
yeah im bored...
my first tech related contribution
Old Jul 8, 2005 | 11:20 AM
Ricey McRicerton's Avatar
Default Re: FIrst Tech Post: DIY HEADUNIT cooling. (needaimport)
Good contribution. I've had a couple of higher end headunits (including my current indash DVD player) and have problems with amps overheating, but never my headunit.
I'd also suggest if you do plan to do this, go ahead and wire the fan to a switched power source (possibly the same switched power that your headunit runs off of) instead of a switch. I can pretty much guarantee that at least one time you'll forget (unless the fan is loud as a bitch) and you'll come out to a dead car.
Old Jul 8, 2005 | 11:22 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: FIrst Tech Post: DIY HEADUNIT cooling. (Ricey McRicerton)
LOL, That's a GREAT idea!! Creative
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'd also suggest if you do plan to do this, go ahead and wire the fan to a switched power source (possibly the same switched power that your headunit runs off of) instead of a switch. I</TD></TR></TABLE>
This makes a hell of a lot of sense as well.
Old Jul 8, 2005 | 11:23 AM
litterbox's Avatar
Default Re: FIrst Tech Post: DIY HEADUNIT cooling. (litterbox)
I don't know why, but this pic makes me laugh:
Old Jul 8, 2005 | 11:28 AM
mike81's Avatar
cool
Old Jul 8, 2005 | 11:29 AM
the fan doesnt stay on if your car is shut down
Old Jul 8, 2005 | 11:32 AM
Royal_C!ty's Avatar
Default Re: (needaimport)
Pretty genius idea to help cool the deck , definite kudos from me
Old Jul 8, 2005 | 11:46 AM
SpoonEK2's Avatar
Default Re: (eg8kid)
Does the headunit really need cooling?
Old Jul 8, 2005 | 11:48 AM
egyolk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why, but this pic makes me laugh:
HAHAHA it makes me laugh too!
i thought decks were made to withstand all the heat of basking in the sun, and heavy usage, but great diy none the less
Old Jul 8, 2005 | 11:51 AM
Sturmcrow's Avatar
Default Re: (oversteerINGS)
My Sony seems to start skipping more often after it gets hot. I'll definately be on the lookout for a used fan now The only problem is, where will I keep my coins?
Old Jul 8, 2005 | 12:13 PM
Default Re: FIrst Tech Post: DIY HEADUNIT cooling. (mike81)
i couldnt find anytihn to cut it with so i used my switchblade. it really didnt matter cus the button would be covering it anyways.
Old Jul 8, 2005 | 12:16 PM
Deemeetree's Avatar
Electrician
Too bad I smoke and need my ashtray.
&lt;---- Bad bad bad moderator!
Old Jul 8, 2005 | 12:23 PM
Hatchamaback's Avatar
Good stuff man!
Old Jul 8, 2005 | 12:54 PM
litterbox's Avatar
Default Re: (Hatchamaback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Too bad I smoke and need my ashtray.
&lt;---- Bad bad bad moderator! </TD></TR></TABLE>Come on Dimi, just roll down your window to blow ashes out there.
Old Jul 8, 2005 | 12:55 PM
Deemeetree's Avatar
Electrician
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Come on Dimi, just roll down your window to blow ashes out there.</TD></TR></TABLE>
Smoking + 100* = sweaty *****. I need the A/C while I smoke.
Old Jul 8, 2005 | 12:59 PM
derspi's Avatar
Default Re: (Sturmcrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sturmcrow &raquo;</TD></TR><TR><TD CLASS="quote">My Sony seems to start skipping more often after it gets hot. I'll definately be on the lookout for a used fan now The only problem is, where will I keep my coins?</TD></TR></TABLE>
I think the obvious answer is there's something wrong with your Sony deck I mean, Sony decks aren't known for their reliability.
Thanks for sharing your creative "mod" but like someone else mentioned, I have yet to hear of a deck overheating, even under extended use in hot summer weather. That fan would be put to better use in an amp rack.
Old Jul 8, 2005 | 01:14 PM
i guess, but i dont have an amp, lo.
besides im in TEXAS!
Old Jul 8, 2005 | 01:20 PM
Redline96LX's Avatar
* B A N N E D *
Wow, thats like so....i dont know. Hehe.
But sir, 100 points to you for pioneering this on your car. Its this kind of ingenuity that starts up new stuff. Ya already got me thinkin of ways to do this on my EK and other ways of building. Thanks for making this DIY, and I hope it helps many more. Now excuse me, I'm going to go get a screwdriver and a dremel and I'll be back in a few hours....
Old Jul 8, 2005 | 01:24 PM
litterbox's Avatar
Default Re: FIrst Tech Post: DIY HEADUNIT cooling. (Redline96LX)
Bwahahaha I read teh whole writeup again, funny stuff.
Smoking + 100* = sweaty *****. I need the A/C while I smoke. </TD></TR></TABLE>Smoking + 100* + NO AC = me
It blows.
DC-4-Drew's Avatar
Default Re: (SpoonEK2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonEK2 &raquo;</TD></TR><TR><TD CLASS="quote">Does the headunit really need cooling? </TD></TR></TABLE>
I had a clarion unit that overheated constantly! Good write up.
Old Jul 8, 2005 | 01:29 PM
nub.96ek's Avatar
Default Re: (Deemeetree)
Litter the countrside with cig butts lik I do...
Old Jul 8, 2005 | 01:34 PM
Jowee's Avatar
Default Re: (nub.96ek)
Good idea. I've noticed that my cd player doesn't read as well whenever it gets really hot. Now to try it on a teg.
Old Jul 8, 2005 | 01:58 PM
igo4bmx's Avatar
there's your problem...
don't buy sony lol
Old Jul 8, 2005 | 02:24 PM
FlipEGDriver's Avatar
haha nice touch. very creative
Old Jul 8, 2005 | 02:27 PM
menkio's Avatar
Default Re: (FlipEGDriver)
i would prob just cut out the bottom, and then got some screen stuff from home depot, would prob flow a lot more cfm.., or is you wanna be really creative.. take some dryer vents and run one from the upper ac vent, cut a 3x3 hole, and then run the vent to the fan, to the radio underbody, cooling the cd player wether you have ac on or off
