Y8 Dist. wiring help
Old Jul 8, 2005 | 12:28 AM
s73's Avatar
s73
New User
Default Y8 Dist. wiring help
I am putting in a engine for my firends ek (2000 Civic EX) with a same year y8 motor, everything went pretty smoothly, but i encountered one problem. The Plug where the wire harness connects to the Dist is different!!!!!
On his wire harness there is a 8 Pin plug, and the Dist on his new motor has a 10 pin plug (only nine was used tho)....So i pulled out my haynes, and it only ID'ed the 10 pin plug. Now i need to ID all the wires on the 8 pin plug! I searched everywhere and counldn't find any info.
Hope some of you guys can help me out. (ID the 8 pin plug position/wire color i need to connect to the 10 pin plug)
thanks in advance
Old Jul 8, 2005 | 01:13 PM
s73's Avatar
s73
New User
Default Re: Y8 Dist. wiring help (s73)
its cool, found the info i needed
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
j spec
Jul 30, 2006 04:57 PM
tommiboy
Nov 9, 2005 01:21 AM
s73
Jun 8, 2005 12:12 PM
Hatebreed215
Jan 17, 2003 08:26 PM
