Need help with speed sensor...code 17
Old Jul 7, 2005 | 11:59 PM
jonathancrx's Avatar
Default Need help with speed sensor...code 17
I have a 88 crx with b18a1 obd0. I was driving and it started boggin. I pulled over and check engine light came on code 17. Then it woulndt start anymore and I tried reseting the ecu and nothing. Does any one know where I can find some pics of wher its at or maybe someone knows what to do. thanx
Old Jul 8, 2005 | 09:44 PM
Default Re: Need help with speed sensor...code 17 (jonathancrx)
anyone please code 17 on crx with LS. Not the one with the plug. I read somewhere something about a pulser behind the cluster that is part of the system
Old Jul 9, 2005 | 01:04 AM
michael O's Avatar
It's the vss (vehicle speed sensor). I have had a lot of problems with it myself. It runs from the back of your transmission to your gauge cluster. The helm manual is in the garage but it has a troubleshooting procedure for it. You can try and download one or just buy one for $50. Sorry i couldn't be of more help. Maybe someone else can post something informative.
Old Jul 15, 2005 | 10:59 AM
CBURKE's Avatar
having the same prob
Old Jul 15, 2005 | 11:33 AM
DaX's Avatar
DaX
Loved
Community Favorite
Are you using an electric VSS [electrical connection at the tranny] or a cable VSS [cable running from tranny to speedometer]? What ECU are you using? OBD-1 or OBD-0?
Is your speedometer working at all? Does it flutter?
Old Jul 15, 2005 | 10:03 PM
reek's Avatar
Default Re: (DaX)
I've got the same error code with a B16 (PW0 ECU I believe) and a cable VSS. If the ECU is looking for the digital one I could put it back in but then I would need a new cluster plus wiring for the speedo, right?
Old Jul 16, 2005 | 08:27 AM
reek's Avatar
Default Re: (reek)
Anyone know what I should do? (bump)
Old Jul 17, 2005 | 05:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
I think you should be able to feed the ECU the VSS signal from your cluster...I just don't know which wire it is.
boyee1
10
Dec 15, 2007 10:07 AM
SiR_Injected
Oct 21, 2007 07:24 AM
Propulsion
Aug 25, 2004 11:02 PM
iNetForce
Jun 2, 2004 06:25 PM
C-RICKS
Jun 23, 2003 03:08 PM
