annoying rattle at idle
Old Jul 7, 2005 | 11:15 PM
j0nathanl3e's Avatar
Default annoying rattle at idle
ihave a 92 hatch and it has a b18c1 full conversion in it with only 10k miles on it. when it idles, its pretty rumbly and makes an annoying rattling sound. it sounds like a piece of flimsy metal clanking on something. but when i rev it up slightly it goes away since its not as rumbly as when it idles. i looked under the hood to see if anything was hitting and i found nothing. anyone have the same problem or know whats clanking? oh btw, i have ram air intake, ws2 catback, and itr headers if that helps at all. thanks in advance.
Old Jul 7, 2005 | 11:17 PM
The_Todd's Avatar
Farts in the shower
Default Re: annoying rattle at idle (j0nathanl3e)
Check your heat shields either by your header, cat or muffler.
Old Jul 8, 2005 | 12:41 AM
BuCU's Avatar
Default Re: annoying rattle at idle (.ken)
check your lower header bracket...it might be rubbing on the half shaft...thats what happened to me for some odd reason
Old Jul 8, 2005 | 12:54 AM
eJone powereD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">Check your heat shields either by your header, cat or muffler.</TD></TR></TABLE>
yes, check one of those...when i bought my car, i would have the same loud annoying rattle sound at idle at aobut 1500 rpm...removed the lower heatshield on my cat and it went away
Old Jul 8, 2005 | 11:31 AM
Default Re: annoying rattle at idle (eJone powereD)
yea i think its the shield on the cat. it idles awfully low around 750 ish almost 800. but when it goes slightly up its gone. i think im just gona adjust the throtle linkage so that it idles where its supposed to be. that should cover it right?
Old Jul 8, 2005 | 11:34 AM
^^^ i think that can work...try it first before you go on and removing any shields
Old Jul 8, 2005 | 11:45 AM
Db1_77's Avatar
Your car is idling correctly. I believe it's 700 +/- 50.
Old Jul 8, 2005 | 12:00 PM
Default Re: annoying rattle at idle (hatch77)
wow, i always thought that was low haha. i guess not. just got emissions done today and it indicated an idle at 750.
GOLDBERG
45
Mar 2, 2011 12:59 AM
P@@RB@Y
Nov 27, 2005 07:47 AM
chinaski
May 4, 2005 10:01 AM
fongph
Mar 14, 2005 07:37 AM
NinjaTech
Mar 9, 2005 05:14 PM
