Will i pass emissions? ( turbo )
Old Jul 7, 2005 | 09:55 PM
TurboSC's Avatar
Default Will i pass emissions? ( turbo )
So my motor is almost rebuilt, and I'm kind of worried about emissions so here goes:
My car is an OBD1 1995 Integra GS-R...
I'm gonna have the Drag kit on my car with a carsound cat and custom 2.5 exhaust with Thermal muffler ( really not relevant, but i'll put it anyways ). RC 550 injectors, hopefully boosting about 8-12psi. Forged Wiseco pistons ( 8.5:1 ) eagle rods, OEM bearings and gaskets. I'm gonna get the turbo setup tuned with uberdata for a good 4 hours at a very very good shop.... Oh, and I live in Georgia.
Will I fail emissions?
Thanks in advance,
-Sunny
Old Jul 7, 2005 | 10:24 PM
raceACCORDingly's Avatar
is there a visual inspection?
put in the stock injectors with the stock ecu and take out the wastegate spring.
Old Jul 7, 2005 | 10:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (raceACCORDingly)
as long as everything is tuned well, you should pass.
the road test doesnt put enough load on the motor to see boost
Old Jul 8, 2005 | 05:07 AM
200cs's Avatar
Default Re: Will i pass emissions? (TurboSC)
Mine passed fine in Texas. I removed the obd1 computer and 450 injectors and put the stock obd2 and injectors back in. I had to drive it for a few days without boost to get the ecu to show ready in all of the parameters.
Old Jul 8, 2005 | 06:34 AM
Johnyquest's Avatar
Default Re: Will i pass emissions? (200cs)
Mine passed w/ 450's + an AFC about a year ago just as I drive it every day. They don't boost @ the test, just idle and slight load. As long as your car still goes into closed loop as normal, it'll pass. Mine passed w/ flying colors.
Matt
Old Jul 8, 2005 | 07:15 AM
EJ1 wilcox's Avatar
Default Re: Will i pass emissions? (Johnyquest)
It's hard to tell from behind a computer if you will pass or not.
How healthy is the engine? How is your tune? Are your ignition components in good shape?
I have some friends who have passed easily with turbos and some who have failed miserably with turbos... I would take the car in as you have it now and see if you pass, you never know, you just might!... if you don't, then start making adjustments.
raverx3m
Jul 19, 2015 03:32 PM
Teg4e
Feb 6, 2006 11:16 AM
turbod16y8
Apr 10, 2004 10:24 AM
tyflip2
Jan 31, 2004 10:39 AM
TurboIntegra
Jun 19, 2002 11:59 AM
