Clutch Problems (already replaced master cylinder)
Old Jul 7, 2005 | 05:28 PM
M@'s Avatar
M@
Default Clutch Problems (already replaced master cylinder)
I have a 95 Prelude SR-V (VTEC).
Initial Symptoms: I had to pump the clutch to get it to operate, clutch studder.
I replaced the master cylinder. I had trouble bleeding the clutch. Today I finialy got it bleed well. The clutch felt fine for about 2 min while I let the car warm up, and I had to manuver out of the garage with a car behind me. Then I drove around the block, and decided there was some trouble, but not bad. So I decided to drive it more. It got alot worse in the next couple of min.
Current Symptoms: The clutch is hit and miss. It will seem fine, then sometimes it will kinda just not work. It seems like the clutch is pushed in half way. So I just release the clutch and press again and it seems fine. Sometimes there is little clutch studder, and others it will seem really bad. I let it idle in neutral, pressed the clutch and I couldn't get it into gear. So I turn off the car put it in gear and start. Works ok bad studder, and I drove it home. I turn off the car and start it 2 min later. The clutch was 3x harder to press. I start the car, and it wouldn't go into gear. So I turn off the car again put it in gear and start, and the clutch is easy to press again. So I just parked it.
Warped clutch or pressure plate or something? Throwout bearing? Sticky clutch? I've never messed w/ a clutch so I'm pretty clueless.
Thanks
matt
Old Jul 7, 2005 | 06:28 PM
AndyD's Avatar
Default Re: Clutch Problems (M@)
How old is the clutch?
If the clutch pedal is 3x as hard to push in, that leads me to believe it has something to do with the clutch.
Old Jul 7, 2005 | 06:34 PM
Sam1am26's Avatar
Default Re: Clutch Problems (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">How old is the clutch?</TD></TR></TABLE>
That's what I was wondering....
Old Jul 8, 2005 | 08:42 PM
M@'s Avatar
M@
Default Re: Clutch Problems (Sam1am26)
Stock?
Not sure I've had it for a year from 130,000mi to 140,000mi. I have the recepts from 97' (25,000mi).
matt
Old Jul 11, 2005 | 12:43 PM
M@'s Avatar
M@
Should I get an OEM Clutch or aftermarket if that is the problem?
thanks
Old Jul 11, 2005 | 03:19 PM
snobordboy's Avatar
Moderator
Sounds like what I just had happen on my car. My problem was that one of the springs in the center of the clutch disc had broken free. the spring then drags inside the area between clutch disc and flywheel, and occasionally would pop back in spot and the clutch would seem better. I also replaced both master and slave cylinders before figuring this out. I went with the stock replacement Exedy clutch, can be bought off of Ebay or direct from many places, I used Clutchcityonline. They had great customer service and a good price with shipping in my opinion. Are you going to do the job yourself or have a shop do it?
Old Jul 17, 2005 | 01:52 PM
M@'s Avatar
M@
Default Re: Clutch Problems (snobordboi)
Well I was going to have Honda do it, because the only mechanic that I trust dosn't want to work on it.
Is that something that isn't all that difficult?
Should I get an aftermarket clutch or an OEM replacement? The car will remain mostly stock, no serious tuning.
Thanks, and sorry for taking so long to respond.
matt
Old Jul 17, 2005 | 05:12 PM
bubs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">...
matt</TD></TR></TABLE>
It's fairly difficult to replace if you've never done it before. If you're not planning on doing any serious mods, an OEM replacement should do just fine.
Old Jul 19, 2005 | 06:12 PM
M@'s Avatar
M@
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like what I just had happen on my car. My problem was that one of the springs in the center of the clutch disc had broken free. the spring then drags inside the area between clutch disc and flywheel, and occasionally would pop back in spot and the clutch would seem better. I also replaced both master and slave cylinders before figuring this out. </TD></TR></TABLE>
Honda Shop said the same thing.
I'm having Jack Ellena Honda do it .
$1050 1yr parts/labor
The aftermarket looks good, but I think that 140,000mi is pretty good so I'm going to stay w/ the stock, plus I get a warrenty.
Old Jul 19, 2005 | 07:47 PM
scrubachu's Avatar
$1k sounds way steep. most shopw charge about $300 for a clutch job.
Old Jul 19, 2005 | 08:15 PM
Prelude SIR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">I'm having Jack Ellena Honda do it for $1050 1yr parts/lab</TD></TR></TABLE> HOLY ****!!! YOU ARE GETTING BURNED IN THICK FLAMES GO TO A NICE SHOP IT WILL BE ABOUT $700 LESS THAN DEALERSHIP!!!
Old Jul 20, 2005 | 01:55 AM
M@'s Avatar
M@
Default Re: Clutch Problems (jdmhore)
well funny thing is that 300 will just about cover the parts... humm.....
Old Jul 20, 2005 | 08:33 AM
K-Spec's Avatar
labor should be $250-$600 (at most)
Old Jul 20, 2005 | 11:56 AM
scrubachu's Avatar
an exedy oem replacement clutch will run you about $90 shipped. and thats with a PP, cause I just bought one like 4 months ago. if you need a new flywheel, you can get one from a yard for like $40. i dont see how parts are going to cost $300 unless you are getting an aftermarket clutch and PP.
Old Jul 20, 2005 | 03:19 PM
M@'s Avatar
M@
Default Re: Clutch Problems (scrubachu)
http://www.hondaautomotivepart...ERTER
Includes flywheel resurfacing and a warrenty. I'll look at the invoice and try and negotiate if there is something out of place. One thing, the car is Canadian, and rusted pretty bad so I would rather take it there so if they twist off a bolt or something then they cover it(or they should).
Old Jul 20, 2005 | 04:02 PM
scrubachu's Avatar
yea, you are getting killed by oem honda parts. $1k is about right for parts and labor, but defintely not worth it. you will get the exact same results from having a shop resurface your flywheel and installing an oem exedy clutch and PP for 1/3 the price of what you are paying for honda oem parts and install.
732xghost
Dec 22, 2014 09:29 AM
Mikeyb918
Oct 31, 2012 05:55 PM
VisPreludeVtec
May 31, 2007 12:46 PM
iwreakhavoc
Jun 3, 2005 10:47 AM
