Break lights wont go on
Old Jul 7, 2005 | 05:13 PM
wakaba_db1's Avatar
Default Break lights wont go on
my break lights (all 3 of them) dont turn on when the brake is pressed. the bulbs are still good. the lights come on with parking lights, but do not get brighter when break is pressed. i've checked my fuses and was told i might need a new break light switch. any help will be appriciated.
Old Jul 7, 2005 | 05:16 PM
numbnuts22715's Avatar
your bulbs may need replaced or maybe the brake light switch...
When my brake light switch broke they would turn on but wouldnt turn off no matter what.
b18cDA's Avatar
Default Re: Break lights wont go on (wakaba_db1)
yea i had the same problem.
check under your dash and above the brake pedal or behind sort of...there will a white sort of pushable button, that goes in when the brake pedal is pressed. Find the wires leading to this and check it for current. If its good, which happened in my case, it was just a wire that had been cut, and had to be repaired.
Old Jul 7, 2005 | 05:17 PM
b18cDA's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">your bulbs may need replaced or maybe the brake light switch...
When my brake light switch broke they would turn on but wouldnt turn off no matter what.</TD></TR></TABLE>
it wasn't broken then, it was only stuck. The piece that moves in and out got stuck in the in position, and that is why they were always on.
Old Jul 7, 2005 | 05:24 PM
wakaba_db1's Avatar
yea i'll go check the connections again. i was also told to check the ground wires on the bulbs.
Old Jul 7, 2005 | 08:09 PM
teddy_dc2's Avatar
do you have a sound system? any gauges like an aftermarket tachometer? i had a similar problem but i started with the fuse blowing everytime i put a new one in, turns out one of my speakers were stripped and touching a ground.
Old Jul 8, 2005 | 12:44 AM
wakaba_db1's Avatar
yes i have a sound system. i might look into that later on. thanks for the help guys.
TomCurllyFry
Mar 25, 2013 09:29 PM
hershy253
Jun 1, 2011 08:35 AM
neogenesis2004
Mar 3, 2009 04:21 PM
XMANZREX
Oct 19, 2008 03:54 PM
virusx
Apr 28, 2005 12:13 PM
