Engine swap with a/c
Old Jul 7, 2005 | 01:59 PM
1tyme's Avatar
Default Engine swap with a/c
I just bought a 89 crx with A/C I want to drop my b16 inside and retain my A/C is this possible and do I have to mod anything.
Old Jul 7, 2005 | 02:26 PM
JKingCivicSi's Avatar
Default Re: Engine swap with a/c (1tyme)
Hasport sells a custom AC bracket for that. When you do your swap just rest the AC on the frame of the car and it will be out of the way.
http://www.hasport.com/Product...1.htm
Old Jul 7, 2005 | 02:58 PM
Smokinsax's Avatar
The Boot
I just purchased the AC bracket from HASport. It comes with all the hardware needed. The quality of the bracket is super nice!
Old Jul 7, 2005 | 03:44 PM
b18_crx's Avatar
Default Re: (Smokinsax)
i heard u can also use bracket from b16 usdm del sol.........someone verify this
Old Jul 7, 2005 | 08:03 PM
Smokinsax's Avatar
The Boot
Default Re: (b18_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">i heard u can also use bracket from b16 usdm del sol.........someone verify this</TD></TR></TABLE>ive heard this too...when I called up Honda Auto Salvage, to buy one, they told me it wouldnt work...then they sent me to HASport
Old Jul 8, 2005 | 12:42 AM
JOSEPH's Avatar
my 89 crx si with a b18 swap has a/c. I used the 93 integra a/c bracket to bolt on the crx a/c compressor to it.
Old Jul 9, 2005 | 04:37 AM
StorminMatt's Avatar
Default Re: Engine swap with a/c (JOSEPH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOSEPH &raquo;</TD></TR><TR><TD CLASS="quote">my 89 crx si with a b18 swap has a/c. I used the 93 integra a/c bracket to bolt on the crx a/c compressor to it. </TD></TR></TABLE>
This works. But you can't use all the bolt holes. And you MAY have crossmember interference issues.
Old Jul 9, 2005 | 04:54 AM
RA122324's Avatar
Here's a question:
Can you use the A/C Compressor that's already on the engine (Like a B16 swap for example) and get longer lines if you needed to?
Old Jul 10, 2005 | 04:48 AM
Default Re: (knwldge54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knwldge54 &raquo;</TD></TR><TR><TD CLASS="quote">Here's a question:
Can you use the A/C Compressor that's already on the engine (Like a B16 swap for example) and get longer lines if you needed to?</TD></TR></TABLE>
You probably could, provided there are no crossmember interference problems.
One more thing. The Integra bracket will only work with the Sanden compressor. With the Matsushita, a custom bracket is required.
Mrevann
May 19, 2011 01:02 PM
BlackEG6
11
Aug 3, 2007 05:30 PM
System-7
Mar 23, 2006 05:40 AM
SoInCiv
Jun 17, 2005 06:23 AM
Jonnyr4c
Nov 20, 2004 12:42 PM
