titanium retainers install Q
Old Feb 14, 2002 | 10:14 PM
StinkyTofu's Avatar
Default titanium retainers install Q
I've heard that you can install valve springs onto your head without removing it, is it possible to do it without removing the head for a titanium retainer installation?
Old Feb 14, 2002 | 10:18 PM
infinkc's Avatar
Default Re: titanium retainers install Q (B-18C1)
um you have to remove retainers to change out your springs, so if you can remove the springs with the head on, YES you can remove the retainers.
Old Feb 14, 2002 | 11:15 PM
StinkyTofu's Avatar
Default Re: titanium retainers install Q (infinkc)
thanks i just wasn't aware of where the retainers were...i'm obviously not doing the installation and i would hate the person to charge me double for nothing, thanks for the heads up
Old Feb 15, 2002 | 05:46 AM
rtype11's Avatar
I would suggest you remove the head, doing it without removal can end up being more work in the end, like when you go to put the keepers back while compressing the spring you may lose some and have to go hunt in the block or head, you should also used compressed air through a spark plug fitting with pistons TDC to keep the valves from dropping.
slipstreamsi
May 30, 2004 06:07 PM
darrinbrewer
Feb 9, 2003 11:03 AM
arw321
Dec 6, 2002 03:00 PM
jabroni95gsr
Nov 19, 2002 08:17 AM
forksports
Dec 4, 2001 10:10 AM
