v-tec and non v-tec exhausts
Old Jul 6, 2005 | 08:50 PM
pr1mo_13's Avatar
Default v-tec and non v-tec exhausts
is there a difference? definatly need to replace the stock exhaust that was treated to a welded on ghetto muffler before i bought the car. i'm thinking apexi ws or something else decently quiet but a good tone to it and was wondering since i'll be h22 swapping i'll need a h22 header/downpipe and from cat back i need something for non v-tec or does it not matter? sorry i'm i sound retarded, just got off work and it's time for bed
Old Jul 6, 2005 | 09:28 PM
IAluder95's Avatar
the only thing different between the two exhuasts is the test pipes bolt. buy a Vtec cat convert and it will bolt it up.
Old Jul 7, 2005 | 03:28 AM
clemsoncb7's Avatar
Default Re: (IAluder95)
Yup, exactly what IAluder95 said, the vtec cat. is a little longer so all you need is one of those.
Old Jul 7, 2005 | 06:37 AM
pr1mo_13's Avatar
so i'll need vtec header, downpipe and if i choose to replace the cat-back system, i'll need to get a v-tec cat. but if I don't, the v-tec header and downpipe will all i need for now?
Old Jul 7, 2005 | 06:44 AM
uncle's Avatar
Default Re: v-tec and non v-tec exhausts (pr1mo_13)
What the **** are you guys talking about? VTEC cat?
Old Jul 7, 2005 | 08:59 AM
Daily Interlude's Avatar
I think they are trying to say that to use a VTEC header and downpipe on a non-VTEC exhaust and engine setup that you'd need to also use a VTEC cat converter too (it's apparently longer).
Old Jul 7, 2005 | 09:26 AM
pr1mo_13's Avatar
no, this is on a v-tec motor. i am swappipng in an h22 from an h23 4th gen. once the h22 is in i will need v-tec header and downpipe if i retain stock cat-back.
if i replace cat-back i will need to buy v-tec cat and cat-back
(please correct me if I am wrong)
Old Jul 7, 2005 | 11:00 AM
OK, so you're swapping the engine then too. It's probably the same thing. You'll need up to the cat converter since the converter on the VTEC engines are longer...
Old Jul 7, 2005 | 02:51 PM
92SleeperH23's Avatar
Default Re: (Daily Interlude)
subtract the dash, yo
Old Jul 7, 2005 | 06:43 PM
IAluder95's Avatar
ok you have an h23 your swapin in a H22.
you want to use your H23 exhuast. you dont need to change anything, but the cat. header should come with the motor swap.
Old Jul 7, 2005 | 09:39 PM
pr1mo_13's Avatar
ok, so since the header comes with it bolt up the h23 downpipe, v-tec cat, and h23 cat back?
So there is no difference between a non vtec and vtec cat back system? sorry it's hard to understand since i've heard a lot of different stories
Old Jul 7, 2005 | 10:58 PM
SKDRCR's Avatar
Default Re: (pr1mo_13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr1mo_13 &raquo;</TD></TR><TR><TD CLASS="quote">ok, so since the header comes with it bolt up the h23 downpipe, v-tec cat, and h23 cat back?
So there is no difference between a non vtec and vtec cat back system? sorry it's hard to understand since i've heard a lot of different stories</TD></TR></TABLE>
You're making it harder than it really is.
You have a few options.
1. Use the stock h22 exhaust manifold and downpipe, have it lengthend or
reduceed (I can't remember which one ) and bolt it up to your h23 catylitic converter.
2. Buy an aftermarket h22 header/downpipe and get an aftermarket cat (carsound/random technology, etc.),
have a muffler shop bolt everything up for you.
3. Same as option 2 but go with custom exhaust from the downpipe back.
I used the h23 downpipe (dc header) with an h22 dc exhaust manifold
(upper portion) and custom exhaust.
It just depends on what kind of budget your on.
If it's a tight one, go with option 1.
nazafi
Jan 12, 2011 04:36 AM
E46Kid
53
Nov 11, 2005 02:35 PM
b16mike
40
Sep 30, 2005 03:51 PM
josh200536
Jul 8, 2005 11:07 AM
b18c1vtec
Jun 9, 2005 01:04 PM
