b16 swap n 91 civic si what throttle cable do i need
i've just put in my obdo b16 swap in to my 91 civic si what throotle cable do i need
i'm also having problems with my clutch cable going onto the tranny do i have to ben the bracket or use another one
the tranny i'm using is a ysk 1 cable tranny what do i have to do to make my 91 civic si clutch cable work withe that tranny
Your stock clutch cable will work its just a lil tricky to get on cause its a lil too short. However if you have soem extra cash buy a 90-93 teg clutch cable
you can use the si throttle cable but you have to modify the throttle bracket, the clutch cable should fit you might have to use different brackets
Dc4iNtEgRa
11
Feb 29, 2008 10:18 AM
4gencivicef9
Apr 9, 2006 07:18 PM
ironchef25
10
Jan 20, 2004 12:26 PM
90civichbsi
12
Sep 9, 2002 06:41 PM
BoostinDC2
Feb 17, 2002 05:41 PM
