d15b into 88 civic dx? i have p28 ecu and ecu obd0 to obd1 harness. now what?
i recently bought an 88 civic dx dpfi... i also bought a jdm d15b motor. so i already have a p28 ecu and the ecu harness adapter and i want to install this motor but not sure about the wiring of the 4 injectors and maybe a few sensors i have to wire but am not sure which ones.... this motor came with a cut harness so the plugs and wires a all there for me to splice but i need some help... thanks a bunch
a saw a few threads on converting just dpfi to mpfi but non that explained going obd1 ... thank you
http://www.rywire.com
There's too much to explain
checkout that page, it gives you some idea of what we do.
Before you start cutting up your harness, think about spending $175 on us doing the MPFI conversion with the VTEC wiring run for you. There are actually only 6 solders (cuts) in our entire wiring job for that engine. You can de-pin most of those plugs.
checkout that page, it gives you some idea of what we do.Before you start cutting up your harness, think about spending $175 on us doing the MPFI conversion with the VTEC wiring run for you. There are actually only 6 solders (cuts) in our entire wiring job for that engine. You can de-pin most of those plugs.
Teal95Coupe
Aug 16, 2004 07:53 PM
