New motor cranking but not starting....
It Fires a few times and then dies and shakes alot. Also fuel pours out of the end of the fuel rail afterwards, It seems to me mabye some of the injectors are not firing?
Now I just put this in as a Longblock swap which means It should start right up with no fine tuning. (the mototr was started a week ago and tested) since then it has been put in anotehr car but It should still be set right. Where do I start troubleshooting? Is there a way to see if all of the injectors are firing? I lost the metal clip for one injector, That wount cause it not to fire will it? It is pushed in tight.
[Modified by Speed_Ricer99, 11:20 PM 2/14/2002]
Is that the clear thing at the end of the fuel rail? if so. yes... But I dont think it is bad, because when I took it off after cranking fuel shot over me and the entire engine bay, thats why I quit for the night, I Thing the injectors arent firing
bambbrose
Sep 2, 2007 04:58 AM
e jay one
Sep 10, 2005 11:31 AM
