((((((((((!!!!HELP!!!!!)))))))))))))))))BLINKERS DONT WORK!
Ok i did a swap for my 89 Dx hatch. But i did the wrong way of doing it i bought the whole 91 si harness inside and out. now i hooked everything up but on my 89 the hazard are in the middle of the steering calum. A small thin clips goes there but the 91 harness didnt have that it had the thick one. also i got the stock dx cluster do i need the 91 si cluster. Also do i need the 91 si black lil box behind the steering wheel and the cover for the cluster because on the 90-91 have the hazard switch on the cover.
Cant really tell but do you have a hazard plug pluged in?
If you dont have one plugged in the turn signals wont work at all.
not trying to be the dumb azz here but wheres the harzerd plug cause my blinkers dont work ethier,i dont have it plugged in or my blinker relay in the fuse box is bad.but if u can show a pic of the plug so i know if it is hooked up
n8barton
Jul 16, 2004 11:36 AM
