suspension problems! i need help ASAP
Old Jul 6, 2005 | 12:35 PM
iHATEspeedbumps.'s Avatar
Default suspension problems! i need help ASAP
so heres the story, i bought a 94 LS that has been hit in the front passenger side. i looked at it before i bought it thinkin it was an easy fix. i thot it was only the upper control arm since that shiizz was broken into pieces. so i changed that out and now my control arm is rubbing my springs and the wheel has hella negative camber. i believe it is the lower control arm, but i am not sure. here are some pix to help explain better.
Old Jul 6, 2005 | 12:40 PM
smkngsr's Avatar
Default Re: suspension problems! i need help ASAP (iDISLIKEspeedbumps.)
its going to be really hard to tell which is bent and damage and all that until you get another teggy and compare it...id recommend you get another teggy and jack it up or try to switch the suspension from another teggy so at least you can see which of the parts needed the replacement as supposed to repair...
Old Jul 6, 2005 | 12:44 PM
Lan's Avatar
Lan
Default Re: suspension problems! i need help ASAP (smkngsr)
Yeah same thing.. I would pull the wheel off so you can get a pic from the side. Looks like you have to replace the spindle and the upper a arm. Hopefully the mounts for the upper a arm are ok. Good luck and post another pic if you can.
Old Jul 6, 2005 | 12:51 PM
TurBoTeG's Avatar
that spindle looks pretty tweaked....hopefully thats the only thing...
Old Jul 6, 2005 | 12:55 PM
Default Re: (TurBoTeG)
sorry to sound like a dumbass but which arm is the "A arm" and what is a spindle?
Old Jul 6, 2005 | 03:41 PM
mattssi's Avatar
Default Re: (iDISLIKEspeedbumps.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iDISLIKEspeedbumps. &raquo;</TD></TR><TR><TD CLASS="quote">sorry to sound like a dumbass but which arm is the "A arm" and what is a spindle?</TD></TR></TABLE> the spindle is also commonly called the hub assembly. it is the solid piece that the rotor and the upper and lower control armn bolt to. And the steering assemly too. the a-arm i think you alread replaced?
sbuilt2ride
Suspension & Brakes
Oct 16, 2009 08:04 AM
pdotjones
Dec 19, 2006 10:02 PM
gnar kill
Apr 27, 2005 06:51 AM
