Power strearing on a b18c swap... I need some help...
Old Jul 6, 2005 | 12:14 PM
O-sin's Avatar
Default Power strearing on a b18c swap... I need some help...
I have a 98 civic ex coupe. i am replacing the d16y8 with a 94 b18c however, the power steering pump on the GSR doesn't fit the power steering hose on the EX... and it doesn't look like the pump from the d16y8 is gonna work... what should i do??
Old Jul 6, 2005 | 03:29 PM
Above6K's Avatar
Default Re: Power strearing on a b18c swap... I need some help... (O-sin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O-sin &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 civic ex coupe. i am replacing the d16y8 with a 94 b18c however, the power steering pump on the GSR doesn't fit the power steering hose on the EX... and it doesn't look like the pump from the d16y8 is gonna work... what should i do??</TD></TR></TABLE>
The pump you need is one from a 98-01 Integra. They're slighly different from the older ones and will bolt right up to your Civic pwer steering line. Make sure you use the upper bracket from the GSR as well.
Old Jul 6, 2005 | 08:31 PM
O-sin's Avatar
Default Re: Power strearing on a b18c swap... I need some help... (Above6K)
ok cool thanks alot man
MRturbo
May 29, 2006 12:55 PM
O-sin
Jul 6, 2005 08:29 PM
bigblockEG
Aug 10, 2003 05:08 PM
Drkaccrd
Jan 30, 2003 02:30 PM
