Cam Question?????
GOt a D15B2(yes I know it is next to botom of the barrel____)Will a SOHC ZC"s
cam bolt up or a 1.6L Si cam??
NOTE: Im shimming the head so my factory clearance will be considerably dimmenished.
Yes the cam from a sohc ZC or d16a6 will bolt in to the d15b2...it is basically the same head casting. By shimming I am thinking you mean milling it to up the compression?? In this case I would clay the motor with the cam of choice to check to make sure you have adequate clearance between the valves and pistons.
