Quick Wiring harness Question, JDM B16, OBD1, chipped P28, 93 CX
Im getting a JDM OBD1 B16 from Steve at HMO. I have a 93 Civic CX and a Kenji chipped P28.
Should I call Larry Jr. and get a wiring harness from an OBD1 VTEC car?
What's his phone number?
You dont have to get a vtec harness. You will have to extend the wires regardless unless you want to get the harness perfectly setup so you might as well just use the harness you have and add the vtec wires to it. I just did my swap and had to extend the intake air temp wire about 6 inches and extend the vtec wires but its not a big deal. You also need to wire vtec from the shock tower to the ecu.
