car down
Old Jul 5, 2005 | 08:58 PM
G2_Fella's Avatar
Default car down
i was about to go and pay the rent today. phucking car died on me. engine still starts but gear doesn't want to go in and clutch is loose. what is the problem? is there a tranny involve or is this just a clutch?
Old Jul 6, 2005 | 11:14 AM
G2_Fella's Avatar
Default Re: car down (G2_Fella)
nobody?
Old Jul 6, 2005 | 11:15 AM
EP3_05's Avatar
Check to see if the clutch cable broke...Is there any pressure when you push the clutch in or does it just go right to the floor like there is nothing holding it back
Old Jul 6, 2005 | 12:06 PM
G2_Fella's Avatar
Default Re: car down (91civic)
it goes right to the floor. car does start but can't shift into any gear. what is the problem?
Old Jul 6, 2005 | 12:20 PM
EP3_05's Avatar
First check to make sure your clutch cable hasn't snapped and is connected to both the transmission and the pedal assembly before you start tearing into the clutch or transmission.
Old Jul 6, 2005 | 12:28 PM
G2_Fella's Avatar
how would i check that. please give me a step be step. and the car is parked in front of somebody's house different neighborhood. i haven't check on the car yet.
Old Jul 6, 2005 | 12:32 PM
EP3_05's Avatar
1. Get under the dash and make sure the cable is attached to clutch pedal
2. Go into the engine bay and make sure the cable is attached to the trans. The cable attaches to a black arm right near the battery
3. Have a friend push the clutch pedal in and watch the black arm. If the cable pulls the arm then the cable is fine and it is something inside the trans
Old Jul 6, 2005 | 01:47 PM
G2_Fella's Avatar
which side of dash? passenger side or driver side.
Old Jul 6, 2005 | 01:48 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella &raquo;</TD></TR><TR><TD CLASS="quote">which side of dash? passenger side or driver side.</TD></TR></TABLE>
Driver side where the pedal is
Old Jul 6, 2005 | 01:56 PM
G2_Fella's Avatar
i will write this down and i will go out and check on ma EF. i hope the car is still in one piece.
what if everything is in tact? what would be the problem?
i called one of the local shop for exedy organic clutch. he quoted me $85 out the door. is that good?
Old Jul 6, 2005 | 02:10 PM
Andy R's Avatar
If its not the cable, the clutch plate won't be the problem. It would be related to the linkage arm or the release arm. Not to be mean, but you really don't know much about cars do you? This is some pretty basic stuff man.
Old Jul 6, 2005 | 03:08 PM
G2_Fella's Avatar
Default Re: car down (Andy R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy R &raquo;</TD></TR><TR><TD CLASS="quote"> Not to be mean, but you really don't know much about cars do you? This is some pretty basic stuff man.</TD></TR></TABLE>
i'm glad you asked me that. unfortunately i don't know about cars from the whole bottom roots. if i did, i wouldn't come here and waste my time.
AdRoz
Transmission & Drivetrain
Aug 19, 2009 08:37 PM
fcjohnny
10
May 23, 2009 02:57 PM
speedfreek128
10
Mar 28, 2008 07:45 PM
Solscud007
Oct 13, 2006 05:58 AM
1SIKEF8B20VTEC
Oct 5, 2005 04:44 PM
