Can having to stiff of a valve spring hamper performance??????
i was thinking about purchasing the port flow inner spring in conjuction with the ITR outer. i have a P28 ECU, kenji spec, and the limiter is set at 9100rpm. now if i miss shift, i want to make sure that i dont spin a valve. i have heard, somewhere, that having a valve spring that is too stiff for the cam, i have stock ITR cams, that it will hamper performance. is this true?????? also, do you think that 11:3:1 will be an ideal compression for the stock cams.
jeff
jeff
yes you can have too stiff of a valve spring....you should only use a spring that is the nessesary stiffness.
and ive never heard of a "spun" valve.......bent? thats a possibility
gabrielsousa
Dec 19, 2015 03:51 PM
Screamer
Dec 17, 2003 04:41 PM
