Windsheild spray does not work.
Ive got a 95 accord ex, and recently the windsheild wiper fluid has not been spraying. I figured i was just low on fluid, so i filled it up, but still very little spray or none at all. Is it possible that there is not enough pressure? any input as to what i should do is much apprieacated.
most likely if you get little spray the nozzles are plugged ..disconnect hose from nozzle and try washers see if they spary good if so nozzle are plugged if they spray weak you might have a small tear in hose or kinked hose
alclark
Sep 15, 2003 10:06 AM
Bubble Gum Jr.
Jan 1, 2003 12:38 PM
