Anyone use MSD Injectors.. If so any I would like some opinions..
Old Feb 14, 2002 | 03:32 PM
DamonBoost's Avatar
New User
Default Anyone use MSD Injectors.. If so any I would like some opinions..
I can get a great deal on MSD 750 Injectors.. I wanted to know if anyone used them on hondas and what the opinions on them..
Old Feb 14, 2002 | 11:50 PM
VaporTrail's Avatar
New User
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (Damon501)
I'm considering them highly right now. I have heard differing opinions on whether the fit the rail or not. I do know they fit the injector boss just fine though. Need more input
Old Feb 15, 2002 | 12:25 AM
InfamousRS's Avatar
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (VaporTrail)
Does that mean your going to be selling your 550's then?
Old Feb 15, 2002 | 01:47 AM
Lei Siew Long's Avatar
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (BLK94RS)
i'm using the MSD 720's right now. i only had them on the car for about 2 weeks now and only drove the car on two occasions so i can't give you direct feedback because i haven't had them for that long.
so, after enough seat/track time with the car, i'll give you feedback on how they are
Old Feb 15, 2002 | 04:00 AM
d mafia's Avatar
New User
I am using the MSD 50lbs injectors. the only mod to make it fit the stock rail is to get a machine shop to take off some of the material from the top part of the injector . The bottom part fit the bosses perfectly. Also they worked better than a set of Rc 550 i had. Idle was more smooth.
Old Feb 15, 2002 | 06:05 AM
G's Avatar
G
MSD injectors are a ball type. They do have a good spray pattern, and it is more narrow than the regular pintle, but not a stream like disc types. They work as any injector would, but you must not go above 60-70psi of fuel pressure. I had one stick open at 65psi fuel pressure. Other than that, they are cheap and work well at idle, better atomization and stuff......
Old Feb 15, 2002 | 08:34 AM
ArizonaTurbo's Avatar
I have used the 50 lb/hr MSD's. They were able to support 349 whp without any problems. I now have the 72 lb/hr MSD's for my MOnster Turbo build up! They work well are are fairly inexpensive!
Old Feb 15, 2002 | 09:00 AM
VaporTrail's Avatar
New User
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (boostedeg6)
Ok, so did you have to modify anything to make it fit the rail?
Old Feb 15, 2002 | 09:38 AM
InfamousRS's Avatar
Where are you guys getting these Injectors? Who much do the 750's run?
Old Feb 15, 2002 | 09:53 AM
VaporTrail's Avatar
New User
about 400/set. Anyone who carries MSD (which is about EVERYONE) should have them listed in their catalog.
Old Feb 15, 2002 | 10:00 AM
InfamousRS's Avatar
How much are the RC 720's a set? WOuld getting the MSD's be a better choice than the RC 550's (witch I was planning on) for 1 bar?
Old Feb 15, 2002 | 10:05 AM
VaporTrail's Avatar
New User
550's would be a good choice for 1 bar. RC's get really expensive above the 550 range, as they are then a custom injector (175/per injector!).
Old Feb 15, 2002 | 10:11 AM
InfamousRS's Avatar
Kinda off topoic: I will have enough money shortly to buy all of the stuff I need for my rebuild. Only think is, if I get all the stuff now I won't beable to have my block re-sleeved by Golden Eagle. I mad decide to save till the summer, and just try to have my block resleeved and step up to a 84.5mm bore. My question is, will I need larger injectors for a 84.5 mm bore at 1 bar than a 81.5mm bore and 1 bar?
Old Feb 15, 2002 | 10:19 AM
VaporTrail's Avatar
New User
absolutely yes. On even the n/a B20vtecs, the stock injectors don't cut it at all. I've used prelude 290cc injectors, and we still have to push close to 60psi to get the car to supply all the fuel it needs. On a boosted app, this situation is worsened slightly. I'd look into 650's or 720's for a boosted app.
Old Feb 15, 2002 | 10:22 AM
InfamousRS's Avatar
Does importparts or summit sell the MSD injectors? Would the MSD 750 be a good choice for a 84.5mm bore? I haven't decided yet if I want a vtec head if that has anything to do with it.
Would Hondata beable to idle 750's well?
[Modified by BLK94RS, 7:23 PM 2/15/2002]
Old Feb 15, 2002 | 11:07 AM
I am running a Jim Wolf Technology fuel rail, but they pretty much fit into any aftermarket rail that allows top feed injectors. The MSD's are only like $90.00 each, at least that is what I sell them at. THe 50 lb injectors are 12 ohm and the 72 lb injectors are 2 ohm, so you will need to run a Ballast resistor inline.
Old Feb 15, 2002 | 11:09 AM
1fstevo's Avatar
New User
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (2FAST4U)
So, shaving top part of the injectors is the only mod. Can anyone get a little more detail on it like where to cut and shave. Pic would be great!!
Old Feb 15, 2002 | 11:11 AM
You may have some idle problems before teh car warms up, but once it does it should be fine! Here is a pic to my fuel rail with MSD injectors:
Old Feb 15, 2002 | 06:47 PM
InfamousRS's Avatar
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (APEXSER)
Are the MSD injectors made by the MSD ignition company? I can't seem to find any info on the injectors on http://www.msdignition.com .
Old Feb 15, 2002 | 10:40 PM
paulzy's Avatar
do they come with the connectors?
Whaqt I always wondered is what the conversion is for lbs/hr and cc? For example, I always thought that likr 550cc injectors are the same as 55lb injectors
Old Feb 16, 2002 | 01:50 AM
VaporTrail's Avatar
New User
Default Re: Anyone use MSD Injectors.. If so any I would like some opinions.. (Slow_ass_4dr)
no, they don't come with connectors, but you should be able to use CRX Si injector clips - don't quote me on that though. Want more info?
http://www.msdignition.com/fuel_1.htm
Old Feb 16, 2002 | 05:57 AM
The connectors are like $10.00-$15.00 for all 4. The MSD 50 lb/hr injectors are + 525cc injectors.
Old Feb 16, 2002 | 08:12 AM
VaporTrail's Avatar
New User
the conversion is 72lbs x 10.5092 = 756.6624cc/min
Old Feb 18, 2002 | 07:38 AM
i'm using the AEM rail and the fit was perfect. don't know about the stock rail though.
Old Feb 18, 2002 | 10:54 AM
VaporTrail's Avatar
New User
didnt have to shave anything? Interesting info. Thanks
