What else would i need to complete the swap
Let's say i buy a b16a complete chageover for my 90 crx from http://www.hondamotorsonline.com what else would i need to swap it in?
WOuld i need to buy new motormounts?
also how bad would the wiring be?
one more thing is there a site i can goto with step by step?
sorry for all the questions thanx for the help
Yes you would need motor mounts. I dont think the wiring is too bad, you can buy a wiring harness conversion. Try doing a search and all your questions will be answered.
http://www.hybrid.honda-perf.org
click on the 4G tech
the wiring is "supposed" to take 4-6 hrs. i personally would rather buy hte wiring harness from HASport. no wiring headaches that way. as far as othe things go, you might as well replace the usual water pump and timing belt while the motor is off.
thanx for the site and the tips i think i'm gonna go zc thoguh just because it's easier and this will be my first swap.
i got a zc for you!!!! i live in chicago and my zc is going to b replace by a b16!!! f/s blk cover zc with dc integra header, act clutch used for a year!!!!$600
600? what trans do you have with it? also how many miles have you put on the motor and what did you replace when you did the swap (ex: water pump timing belt any seals?)
ITR607
Sep 14, 2002 03:38 PM
