Help: Ground wire bolt size for valve cover?
Old Jul 5, 2005 | 08:03 AM
onyx00's Avatar
Default Help: Ground wire bolt size for valve cover?
Well, dumb me, I lost the bolt for the engine ground wire (goes from the frame to the valve cover). It is the bolt that connects the ground wire to the valve cover. Does anyone know the size of this? I am hoping I can go to the hardware store and get what I need.
Thanks!
Old Jul 5, 2005 | 08:48 AM
Bbasso's Avatar
Default Re: Help: Ground wire bolt size for valve cover? (onyx00)
Does this help?
Old Jul 5, 2005 | 09:00 AM
onyx00's Avatar
Default Re: Help: Ground wire bolt size for valve cover? (Bbasso)
Unfortunately not really; doesn't give the bolt size
I think I can guess and check on it; there are other bolts that are close in size so I can use them as reference.
Course, I now managed to strip out the bolt on the frame, but I am hoping it will still give a decent ground.
Old Jul 5, 2005 | 09:05 AM
splitime's Avatar
Proper ground is to the stud in that corner... just undo the nut and put the ground strap onto the stud... then it effectively grounds the head.
If you lost the one that goes to the chassis... its a 10mm.
Old Jul 6, 2005 | 07:58 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately not really; doesn't give the bolt size</TD></TR></TABLE> ?
"6 x 1.0 mm"
Old Jul 6, 2005 | 08:43 AM
cjames235's Avatar
Default Re: Help: Ground wire bolt size for valve cover? (Willard)
edit: im a we-todd..... i re-read the original post
Modified by cjames235 at 4:34 PM 7/6/2005
Old Jul 6, 2005 | 09:49 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
"6 x 1.0 mm"</TD></TR></TABLE>
Old Jul 6, 2005 | 11:40 AM
DADADAAAMN's Avatar
i agree 6x1.0mm
Old Jul 6, 2005 | 01:05 PM
R you serious's Avatar
32mm chris
Hyunbs
Mar 11, 2013 11:35 AM
acake em1
Apr 30, 2009 08:21 PM
LoseRPunKx182
Aug 8, 2005 12:49 PM
es_squared
Jul 4, 2004 04:24 PM
Ignitecivic
Dec 14, 2003 09:28 PM
