D16Z6 dyno result
Old Jul 5, 2005 | 06:40 AM
Civic TSI's Avatar
Default D16Z6 dyno result
Yellow - 13psi - 284whp
Green - 15psi - 304whp
Pink - 18psi - 312whp
I think the 18psi run is biased. It should have made around 330whp. On the previous run, the stupid WG hose unplugged itself even if it was tie-wraped. So it instantely boosted 30psi. Hopefully it is just a HG. Engine is still running strong but the overflow can is filling up
Runs were made on a 30 Celius (86F) very humid day.
Uberdata tune by me. 11.5 A/F all across the board.
Old Jul 5, 2005 | 06:59 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: D16Z6 dyno result (Civic TSI)
SOHC ninjas reppin' HARD!
Old Jul 5, 2005 | 07:00 AM
ELSpool's Avatar
Looks good Steph, shitty you HG is leaking already on the new motor.
Old Jul 5, 2005 | 07:02 AM
Civic TSI's Avatar
Default Re: (ELSpool)
It wasn't leaking until the 30psi spike
Old Jul 5, 2005 | 07:17 AM
igo4bmx's Avatar
whats the setup
Old Jul 5, 2005 | 07:18 AM
BlackCRX's Avatar
damn nice #'s man
what kinda internals are you running ??
turbo size ??
Old Jul 5, 2005 | 07:20 AM
SOHC_MShue's Avatar
Great numbers man!
PS: it sounds like your headgasket is definintly toast. I've dealt with this in the past
Old Jul 5, 2005 | 07:47 AM
HiProfile's Avatar
Default Re: D16Z6 dyno result (SOHC_MShue)
I'm guessing that's the same motor that's listed on your Tsi page? I just watched those vids the other day, that car's hot.
I'm curious, what made the pink line spool slower? Did you increase the AF for the entire map or what? Regardless, great run & hope its just an easy fix. Not everyone can say they just blew a HG after a 30psi spike
Old Jul 5, 2005 | 07:58 AM
Boltz's Avatar
Default Re: D16Z6 dyno result (HiProfile)
Also curious on the turbo size...
Civic TSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing that's the same motor that's listed on your Tsi page? I just watched those vids the other day, that car's hot.
I'm curious, what made the pink line spool slower? Did you increase the AF for the entire map or what? Regardless, great run & hope its just an easy fix. Not everyone can say they just blew a HG after a 30psi spike </TD></TR></TABLE>
I guess it has to do with the HG. If I would have been tuning my race map, it might have been ok cuz my race map goes up to 29psi, my street map end at 22psi.
SETUP:
http://www.civictsi.com/setup.htm
Also, I'm curious about what the tuners have to say about my TQ curve. I haven't investigated it much but I don't like it, too much up and down.
Old Jul 5, 2005 | 08:17 AM
liam821's Avatar
25 Year Member
wow you're running a 20g eh? Nice power!
Old Jul 5, 2005 | 09:30 AM
clemsonhatch's Avatar
Default Re: D16Z6 dyno result (liam821)
I'm having the same HG prob...what is the best HG you can get???
Old Jul 5, 2005 | 09:59 AM
HitEm'Up's Avatar
nice number
Old Jul 5, 2005 | 11:25 AM
BlackCRX's Avatar
Default Re: D16Z6 dyno result (clemsonhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonhatch &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the same HG prob...what is the best HG you can get???</TD></TR></TABLE>
oem with rtv and copper spray
Old Jul 5, 2005 | 11:41 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI &raquo;</TD></TR><TR><TD CLASS="quote">
Also, I'm curious about what the tuners have to say about my TQ curve. I haven't investigated it much but I don't like it, too much up and down.</TD></TR></TABLE>
Did you tune the timing at all? Also, the major dip where VTAK kicked in needs look at as well.
Nice numbers though!
Old Jul 5, 2005 | 11:57 AM
Civic TSI's Avatar
Default Re: D16Z6 dyno result (ladysman)
I did tune the timing, I gain like 20whp just playing with it and yes I have to look at what happen after the vtec kick-in, it isn't right.
Old Jul 5, 2005 | 02:21 PM
1boostedcivic's Avatar
wow congrats. but just curious why does that say flywheel power on the dyno graph???
Old Jul 5, 2005 | 02:54 PM
RockinSOHC's Avatar
Nice numbers
Old Jul 5, 2005 | 03:08 PM
SOHC_MShue's Avatar
Did you play with the vtec crossover any?
Old Jul 5, 2005 | 03:26 PM
Calvinator's Avatar
what turbo are you running?
Old Jul 5, 2005 | 03:47 PM
GiNuWiNe's Avatar
Default Re: D16Z6 dyno result (xtremeazian)
His running a Mitsubishi TD05-20G Turbo (660cfm)
Old Jul 5, 2005 | 06:46 PM
Drew Peacock's Avatar
Default Re: D16Z6 dyno result (GiNuWiNe)
Flywheel power?
Old Jul 5, 2005 | 06:52 PM
Default Re: D16Z6 dyno result (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Flywheel power? </TD></TR></TABLE>
same thing i asked but got no answer.
Old Jul 5, 2005 | 08:35 PM
Tchleung's Avatar
Always says flywheel on those. it will be wheel power
Old Jul 6, 2005 | 12:05 AM
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Always says flywheel on those. it will be wheel power</TD></TR></TABLE> No not at all.
