JDM half-mast antenna and switch wiring
Old Jul 5, 2005 | 02:43 AM
jdm94ej1's Avatar
Default JDM half-mast antenna and switch wiring
Im trying to see how to wire my JDM half mast antenna for my 4th gen there are 4 wires from the wiring harness from the antenna (green/red - black - yellow/white - white/yellow) and there are 3 wires from the wiring harness on for the switch (green/red - black - yelow/white) does anyone know how to wire them? the antenna already has a relay on it attached to the wiring harness I just need to know how to attach the 2 harnesses in order too make the switch work ... any ideas or am I just confusing? lol
Adam
Old Jul 5, 2005 | 06:08 AM
Prelude SIR-T's Avatar
Default Re: JDM half-mast antenna and switch wiring (jdm93bb4)
bump bump
i would like to know how to do this to if anyone has already done it
Old Jul 6, 2005 | 03:30 PM
jdm94ej1's Avatar
Default Re: JDM half-mast antenna and switch wiring (jdmhore)
I figured it out:
1st: cut the old harness from the car (only black - yellow/white - white/yellow)
2nd: attach the JDM harness from the car (green/red - black - yellow/white - white/yellow JDM has green/red for switch)
3rd: take the switch harness and attach the green/red wire to the green/red on the car harness
4th: make a ground for the black wire I used an e-brake bolt
5th: connect the yellow/white wire from the switch to the yellow/white pn the car haress i used some weird 3 way connector thing that i found and
6th: put the switch where ever it will fit i put mine in the options on the e-brake console
7th: test it out the raio has to be on in order for it to go up and then play with the switch and ur done when u turn the car off it shd go all the way down
I will post some pics tmw shd be alot easier
Old Jul 6, 2005 | 04:43 PM
vinuneuro's Avatar
Im curious to see what it looks like. You wouldnt mind posting some pics?
Old Jul 6, 2005 | 11:03 PM
awesome man post some pics i am going to do this
Old Oct 11, 2005 | 01:51 AM
Akhany's Avatar
I know this is about 3 months old but....
Do you have to have the JDM antenna to make this work? Or did you just wire the switch to your existing antenna?
Old Oct 11, 2005 | 02:20 AM
pentaq's Avatar
Default Re: JDM half-mast antenna and switch wiring (Akhany)
Only JDM antenna will work this way. It has a different pinout (4 except 3)
Old Nov 20, 2005 | 09:04 PM
Dongoesby's Avatar
Default Re: JDM half-mast antenna and switch wiring (pentaq)
Where to find the antenna wires/harness from the car? I curious to know since I'm getting JDM half antenna switch.
Old Nov 20, 2005 | 09:50 PM
blackdelslo's Avatar
Default Re: JDM half-mast antenna and switch wiring (Dongoesby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> JDM half-mast antenna and switch wiring</TD></TR></TABLE>
Sooo, are we talking about ships or integras?
Old Oct 30, 2006 | 04:38 PM
tofu man's Avatar
Default Re: JDM half-mast antenna and switch wiring (jdm93EJ1)
where can i buy all the stuff needed for the half mast setup?
Old Oct 30, 2006 | 06:15 PM
kulrevon's Avatar
Default Re: JDM half-mast antenna and switch wiring (cw.tech)
ebay. just keep looking. the switch is always on there. but its rare for the antenna to be on there.
Old Oct 31, 2006 | 08:40 PM
tofu man's Avatar
Default Re: JDM half-mast antenna and switch wiring (kulrevon)
please pm me a link if you ever see one!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">ebay. just keep looking. the switch is always on there. but its rare for the antenna to be on there.</TD></TR></TABLE>
Old Nov 1, 2006 | 04:12 AM
predledude's Avatar
I replaced my jdm antenna with a universal one, you know the ones to fit any car, not out of choice of course, but the honda one'll prob cost a bomb.
Old Dec 30, 2006 | 05:37 PM
'95 BA8's Avatar
Default Re: JDM half-mast antenna and switch wiring (predledude)
What ever happened to the pictures? I really would like to see the set-up
Devo94ac
Feb 9, 2013 08:23 PM
exr_pd
Audio / Security / Video
Sep 27, 2011 06:37 PM
dc2teg06
Nov 26, 2008 09:43 AM
hondaj05
Apr 12, 2006 08:14 PM
sanders711
Oct 12, 2002 10:28 PM
