Suspension & Brakes Theory, alignment, spring rates....
Getting ready to do a suspension overhaul
Old Jul 4, 2005 | 11:49 PM
JDMlyfestyle's Avatar
Default Getting ready to do a suspension overhaul
Im gonna get all the suspension work done once and get it out of the way.
Im drag racing and dont care to much for auto X. so i dont need huge sway bars and all that.
So am i missing any thing?
i have a 92 cx
parts on order
Omni power DC Sports
Omni LCA
Omni camber kit
Rear disc
15/16" Master Cylinder
Lower ball joints
outer tie rods
inner tie rods
Lcon Traction bars
Old Jul 5, 2005 | 11:30 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Getting ready to do a suspension overhaul (JDMlyfestyle)
You don't need a 15/16 MC unless you install Integra 10.2" front brakes.
You will need a 40/40 proportioning valve for your rear disc swap, and integra 2dr e-brake cables...
Old Jul 5, 2005 | 03:08 PM
already got the 40/40 PV
Old Jul 6, 2005 | 07:43 AM
kommon_sense's Avatar
Default Re: (JDMlyfestyle)
I wouldn't buy the lcon traction bars without first replacing the bushings in the front upper and lower control arms along with changing the compliance bushings on the lcas.
I wouldn't bother with the rear omnipower arms unless yours are damaged.
Don't waste money on the rear discs. Swap to the larger front discs from a Teg or civic EX. Get the front sway bar and lcas while you are at it. Yes the sway will make a difference when launching.
Replace any worn motor mounts, namely the rear, tranny mount, and upper driver's side mount.
Old Jul 6, 2005 | 10:44 PM
well then ill just get a ES kit for the hatch
Old Jul 7, 2005 | 11:36 AM
93civicsedan's Avatar
have fun with the overhaul I recently did the same to my car except I used rear gsr lca. If you need a 15/16 MC I have one for sale.
Jimmy
32
Apr 4, 2011 09:26 PM
amej8
Suspension & Brakes
Mar 9, 2011 10:48 AM
*Boostwerks*
Nov 24, 2006 02:31 PM
grandmasterflex
Jun 17, 2004 10:53 AM
