Which swaybar will clear APEXi N1 catback?
I have an N1 on the R, I wanted to get Neuspeed's sway bar set. But I'm wondering if it'll clear the N1 exhaust. If it won't, which swaybar will? TIA.
neuspeed is only like 19mm. you'd be downgrading your 22mm. Ignore this reply if neuspeed came out with thicker swaybars.
mugen makes a 26mm bar
[Modified by MaliceGSR, 4:15 AM 2/15/2002]
Hmmm...Mugen sounds tasty. 26mm is friggin' thick! You think that will clear the exhaust? I also have a Neuspeed rear lower tie bar too. A lot of sway bars won't work with an aftermarket tie bar either. You think it'll work?
ANDREW D
Mar 17, 2005 05:30 AM
hayabusa160
22
Feb 23, 2004 08:01 PM
DeDonDeRosa
Jan 6, 2004 12:45 PM
