Suspension & Brakes Theory, alignment, spring rates....
tokico's
Old Jul 4, 2005 | 04:18 PM
ERIC!'s Avatar
Default tokico's
how tight should i tighten the strut down on the spring. like how much thread should be showing on the shaft itself. is there a specific amount you should tighten it. thanks in advance
Old Jul 13, 2005 | 04:25 PM
ERIC!'s Avatar
Default Re: tokico's (94integ-ls)
9 days later bump lol
Old Jul 13, 2005 | 04:27 PM
ERIC!'s Avatar
i also have a question about my bump stops. my front bump stops are the stock ones, just cut in half. the rear are the bump stop my tokico's came with. could i shave off like a 1/8-1/4 inch off all the bumps stops to lower my car just a bit more? i know this will decrease ride quality a little but i wanted to know if this would actually lower it enough that it would be noticeable.
Old Jul 13, 2005 | 05:10 PM
Asselin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integ-ls &raquo;</TD></TR><TR><TD CLASS="quote">how tight should i tighten the strut down on the spring. like how much thread should be showing on the shaft itself. is there a specific amount you should tighten it. thanks in advance</TD></TR></TABLE>
It should say in the instructions how much you should torque the nut or whatever your fastening.
Thats the only way to know its right.
Old Jul 13, 2005 | 11:29 PM
Tyson's Avatar
you tighten down the nut until its nice and tight. do not gorilla it! (never gorilla anything on a car..) youll end up splitting the shock rod at the tip. there should be about a 1/4" of thread showing.
i cut my bumpstops in half. not problem. just as long as theres some kind of bumper before the shock rod crashes into the bottom of the shock.
not sure if i read what you were asking correctly, but it seems like you said cutting the bumpstop lowers your car, which it does NOT. it just allows more shock travel which is taken away when you lower your car.
racerx510
Suspension & Brakes
38
Nov 25, 2012 07:20 PM
FlewByU352
Suspension & Brakes
14
Jun 13, 2012 10:31 AM
eg9
Apr 27, 2011 03:31 PM
jayden1295
Suspension & Brakes
Mar 2, 2008 12:05 AM
_Cyclone_
Apr 10, 2005 07:40 PM
