susp. tech rear swaybar work with comptech
Its interesting, the susp. tech. rear swaybar connects not to the LCA, but to the bottom of the shock tower, with a little bracket. look at the pick, its a little "elbow" piece of metal. Anywho, I dont see why I couldnt use the susp. tech. bar in place of the comptech bar, but still use the comptech tiebar...Mainly looking for a tear proof subframe.
Post pics if you got the comptech setup, may help.
Only hang up I can forsee is the comptech tie bar would space the d-brackets away from the subframe about 1/2"... would the sway bar still be able to attach at the endlinks and be vertical? I'm sure they would reach but just wouldn't be exactly vertical.
gakkuken
16
Dec 22, 2003 02:10 PM
