B16 or GSR cams for turbo?
Old Jul 4, 2005 | 03:12 PM
GWInquisitor14's Avatar
Default B16 or GSR cams for turbo?
Ive done some research and found that GSR cams seem to be better than B16 cams for a turbo setup. Right now i have B16 cams in my ls/vtec, does anyone have any information that will make me wanna change them out for a set of GSR cams? Dyno graphs, ect.
Old Jul 4, 2005 | 03:16 PM
Boostage's Avatar
Default Re: B16 or GSR cams for turbo? (GWInquisitor14)
b16a2 cams are the same as GSR cams. if you have b16a1 cams. the you should benefit from upgrading to 94+GSR cams or 99-00 Si cams. or intake cam of any Type R.
Old Jul 4, 2005 | 03:57 PM
b16sedan's Avatar
Default Re: B16 or GSR cams for turbo? (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">b16a2 cams are the same as GSR cams. if you have b16a1 cams. the you should benefit from upgrading to 94+GSR cams or 99-00 Si cams. or intake cam of any Type R.</TD></TR></TABLE>
How do you figure? GSR's have a good amount (12 @ .050 INT, 4 @ .050 EXH) duration and roughly the same lift as the B16 cams, and they definitely are different.
Old Jul 4, 2005 | 03:58 PM
Boosted2K's Avatar
Is this really true, can anybody confirm this.......not that i doubt you Boostage
Old Jul 4, 2005 | 03:59 PM
b16sedan's Avatar
Default Re: B16 or GSR cams for turbo? (b16sedan)
http://forums.evans-tuning.com...=2341
There's GSR's vs. B16's. If I ever have a turbo stock B16 again, GSR cams are one of the first mods I'm doing.
Old Jul 4, 2005 | 04:12 PM
drvfast's Avatar
Gs-r Cams are better. Jeff Evans has a dyno plot between both cams.
Old Jul 4, 2005 | 05:06 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan &raquo;</TD></TR><TR><TD CLASS="quote">
How do you figure? GSR's have a good amount (12 @ .050 INT, 4 @ .050 EXH) duration and roughly the same lift as the B16 cams, and they definitely are different.</TD></TR></TABLE>
click here
99 si cams are the same as gsr cams, its the JDM b16a1 that has smaller cams.
Old Jul 4, 2005 | 07:45 PM
b16sedan's Avatar
click here
99 si cams are the same as gsr cams, its the JDM b16a1 that has smaller cams.</TD></TR></TABLE>
I already posted that link, and it speaks nothing of SI and GSR cams being the same. I was running a USDM B16 head on my old setup and when I swapped to GSR cams they were definitely different, since I needed to change the tune and the car made more power. Where did you hear that SI and GSR cams are the same?
Old Jul 4, 2005 | 09:04 PM
well im almost positive i hae B16a1 cams because my manifold and TB came off the same engine and theyre off a 91 JDM B16. Looks like ill upgrade.
Old Jul 5, 2005 | 05:35 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">well im almost positive i hae B16a1 cams because my manifold and TB came off the same engine and theyre off a 91 JDM B16. Looks like ill upgrade. </TD></TR></TABLE>
I linked to the wrong page
click
Old Jul 5, 2005 | 10:46 PM
tight page but according to that the first gen b16 cams and the GSR cams have the same specs, i didn't think this was true.
Old Jul 17, 2005 | 08:02 AM
Swapped_EG's Avatar
i heard that the 00 gsr cams are different then other gsr cams. anyone know if this is true? not trying to jock your thread just trying to stay informed.
Old Sep 7, 2005 | 06:25 AM
slowdaintegra's Avatar
gsr cams r better by far http://forums.evans-tuning.com...+cams
SIReg9
Aug 13, 2003 03:18 PM
91b16civic
May 13, 2003 04:26 AM
g2style
Feb 3, 2003 01:26 PM
