88 crx firing test?
Old Jul 4, 2005 | 02:43 PM
HADDENWORKS's Avatar
Default 88 crx firing test?
What do you deduct when you pop out any spark plug, plug it back in the spark plug wire and crank the motor and it results with no spark jumping off the electrode?
The motor's symptoms are when you start the engine, it turns over, once you open up the throttle by pressing the gas pedal the motor dies out. Either because lack of spark...I'm open to all suggestions and advice as to diagnose this challenge. T.I.A.
Old Jul 4, 2005 | 03:00 PM
snapso_24's Avatar
Default Re: 88 crx firing test? (HADDENWORKS)
check your wires with a multimeter they should be about 30ohms also incorect gapped plugs remember anything more than i prong plugs cant be gapped just replaced. check the distributor cap and rotor for wear, and replace. i dont think that the coil or ignitor would be bad cause then it wouldnt run at all.
snapso_24's Avatar
check your wires with a multimeter they should be about 30ohms also incorect gapped plugs remember anything more than 1 prong plugs cant be gapped just replaced. check the distributor cap and rotor for wear, and replace. i dont think that the coil or ignitor would be bad cause then it wouldnt run at all.
Old Jul 4, 2005 | 05:40 PM
Bunger's Avatar
Did anything lead up to the problem? Also, were you grounding the plugs when you were testing for spark?
Noo_Ish_mee
Jun 27, 2016 02:44 PM
whiterichard70
Feb 9, 2013 03:05 AM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
EblazeK
Aug 4, 2006 01:02 PM
MoBlack
Nov 28, 2005 09:47 AM
