It's another car doesnt start thread!! 93 GSR
Old Jul 4, 2005 | 11:21 AM
Street Ghost's Avatar
Default It's another car doesnt start thread!! 93 GSR
My friend's 93 GSR is having troubles starting.. it would start for about 2-3 seconds and then die out. It seems like it runs on the primed fuel and then it doesnt get anymore fuel after that, even when you step on the gas.
I'm thinking it might be a fuel pump issue. If we were to swap in a known good fuel pump, would one from a 91 Integra LS work? Or would I need one from a 92+ Honda/Acura?
Also, what might cause a situation like this?
Old Jul 4, 2005 | 05:33 PM
Default Re: It's another car doesnt start thread!! 93 GSR (Street Ghost)
ttt
Old Jul 4, 2005 | 07:45 PM
LeftCorner's Avatar
Try the main fuel relay first - common problem on older Honda/Acura's. Replacing the fuel pump on that car is easier said than done, make that your last resort.
Old Jul 4, 2005 | 09:25 PM
Default Re: It's another car doesnt start thread!! 93 GSR (LeftCorner)
Yeah, I just found out you have to drop the fuel tank for the DAs. Thanks, I'll try the relay first.
Old Jul 4, 2005 | 09:50 PM
Downey's Avatar
check your fuses, connections and gas cap. my guess is its the main relay which is located underneath the dash. its really easy to change. it costs about $65 from the dealer.
UniqueX707
Aug 8, 2012 12:21 PM
moo32moo32
May 16, 2011 01:36 PM
Si2See
Oct 15, 2008 04:44 AM
cybercg
Sep 10, 2006 05:20 PM
whitehf
Aug 6, 2006 01:22 PM
