Blinker problem
Old Jul 4, 2005 | 05:00 AM
Mleach's Avatar
Default Blinker problem
Sometimes they work, sometimes they dont. I replaced the steering stalk. I checked all the fuses for correct amperage. Its hit or mis. If they do work, they are fast, or normal. Its rediculous. I am at a loss here.
Old Jul 4, 2005 | 08:45 AM
E46Kid's Avatar
Check for grounds...i had a similar problem with my coupe..grounds where messed up and they would cause my lights not to work properly similar to ur problem... when i fixed the ground then a fuse would blow..try replacing the flasher..too that might also help
si90rex
Engine Management and Tuning
Mar 4, 2009 07:23 PM
lude1888
Feb 26, 2007 04:46 PM
c-notecoupe
Dec 9, 2001 08:41 AM
