OBD2 code 41
I got a code 41 - Primary Oxygen Sensor - Heater circuit malfunction, from my CEL from a 96 civic, stock ECU. Easy fix? Just replace the O2 sensor? THe primary one is the very first 02 sensor right on top of the exhaust manifold, correct?
I noticed a little rough idle but when accelerating or crusing, it seems fine.
On my car i had a code 41 and just replaced the o2 sensor and it runs fine now that is on my obd 1 im pretty sure the obd 2 primary is the one on the header but im not exactly sure bout that.
primary o2 on OBD2 is on the header/exhaust manifold. 2ndary is on the cat. Check the wiring for your primary first. There is also a way to check if the oxygen sensor is bad. need a voltmeter. I am throwing a code 41 and I am 99.9999999% sure it is wiring. however, you should use process of elimination before dropping money on stuff
use voltmeter on o2.....search...it is on here on how to do it--easy way to tell if it is bad
check wiring -
check wiring -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">you should use process of elimination before dropping money on stuff
Very good idea.
I usually use an ohm meter to measure the resistance of the o2 heater to verify it's bad.
Very good idea.
92 CiViC HB
Mar 14, 2007 03:48 PM
Ya@inlinePRO
Apr 3, 2004 09:51 PM
