Oil pressure switch pinout(simple)
Old Jul 3, 2005 | 03:37 PM
Slavko's Avatar
Default Oil pressure switch pinout(simple)
Got a 97 h22 motor running a p13 ecu.
Does anyone know the pinout for the oil pressure switch that is under the oil filter? I looked at the pinouts for the p13 ecu but i can't find the oil pressure switch on the list.
Modified by Slavko at 4:51 PM 7/3/2005
Old Jul 3, 2005 | 07:10 PM
Altilude's Avatar
Default Re: Oil pressure switch pinout(simple) (Slavko)
it's just a switch - either off or on - and goes directly (for the most part - something about an integrated control circuit - but nevermind) to your low oil pressure light - as a warning light in your cluster - it is not routed thru the p13 ecu, the p13 could care less about that oil pressure - however it does concern itself with the vtec pressure switch.
and since a pic is worth a thousand words.
streetracerof06
May 9, 2006 05:09 PM
92hybridAccord
May 10, 2004 07:12 AM
doublejz
Jan 1, 2004 09:46 PM
