Z6 head-Y7 block, which arp studs needed?
Old Jul 3, 2005 | 02:16 PM
Turbo-Ekhatch's Avatar
Default Z6 head-Y7 block, which arp studs needed?
Hi, it was suggested to me to post here and ask which ARP headstuds I will need when I swap a z6 head onto my y7 block. T.I.A.
Old Jul 3, 2005 | 02:30 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Z6 head-Y7 block, which arp studs needed? (Turbo-Ekhatch)
I would say the Y7 since that is where the studs are threading in to. I'm almost 100% sure that all D-series head bolts have the same thread size and pitch. Can anyone second this?
Old Jul 3, 2005 | 03:25 PM
SPD DMN's Avatar
Default Re: Z6 head-Y7 block, which arp studs needed? (HondaFanatic708)
just did a z6/y7 minime swap, used all original headbolts from my y7... gl
Old Jul 3, 2005 | 03:27 PM
sohcvtec1995's Avatar
Default Re: Z6 head-Y7 block, which arp studs needed? (SPD DMN)
y ones. or z ones. i dnt see where it would matter unless one id longer then the other, but seeing that all d's are pretty much the same.
Old Jul 3, 2005 | 04:36 PM
k thanks for the responses guys.
Old Jul 4, 2005 | 12:01 AM
Default Re: (Turbo-Ekhatch)
ttt
Old Jul 4, 2005 | 12:36 AM
EK k kay's Avatar
I'm not sure if they made y7 studs. The y8 and y7 block are the same so you can use y8 studs on it.
Old Jul 4, 2005 | 03:59 AM
Calvinator's Avatar
Default Re: (chowmien)
I think you would need 1 z6 stud and the rest y7/y8 studs, or the other way around. I forgot what I used for my y8/z6 motor.
Old Jul 6, 2005 | 12:06 AM
Cpt Ben's Avatar
Default Re: (xtremeazian)
bump
VtecKiDD
Sep 21, 2006 02:23 PM
turbo sol
Mar 2, 2006 11:57 AM
Maxpower350
Feb 25, 2006 11:57 AM
AgentJam
Sep 10, 2004 05:15 PM
Cruiser G
Feb 6, 2004 11:26 AM
