Someone Verify my Susupension
Old Jul 3, 2005 | 11:52 AM
VTECisSeXY's Avatar
*insert here*
Default Someone Verify my Susupension
Whats up. Bought a 4 door teg and was told it has type r springs on it (does sit a little lower) now he wasnt sure if it had the shocks/lcas too... Im pretty sure it does but I just want to verify. So I took some pics
Now assuming I have the R lcas if I wanted a R sway bar I WOULD NOT need beaks/BSQ kit right?
Also, if I wanted a lower tie bar I would need one for an R NOT a ls/gsr correct?
Thanks
Old Jul 3, 2005 | 12:10 PM
Tornadom's Avatar
Default Re: Someone Verify my Susupension (VTECisSeXY)
It doesn't look like your car has the type-r shocks or lower control arms. The type-r rear shocks mount to the lower control arm with an eyelet, as opposed to the fork mount found on non type-r integra. As for the springs, I don't know.
Old Jul 3, 2005 | 12:55 PM
VTECisSeXY's Avatar
*insert here*
Default Re: Someone Verify my Susupension (Tornadom)
I wonder why the abs lines are like that then?
Old Jul 3, 2005 | 03:15 PM
wreckedmyteg's Avatar
It looks like an ITR rear control arm and strut to me...
Old Jul 3, 2005 | 04:06 PM
eg6sir-s's Avatar
Default Re: Someone Verify my Susupension (wreckedmyteg)
the sway bar on your picture is a gsr/eg6 sway(14-15mm in size). the lower control arms you have are type-r. the part numbers on the shock body show that they are 97spec type-r shocks.
Old Jul 3, 2005 | 04:11 PM
Yambor's Avatar
Default Re: Someone Verify my Susupension (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">the sway bar on your picture is a gsr/eg6 sway(14-15mm in size). the lower control arms you have are type-r. the part numbers on the shock body show that they are 97spec type-r shocks.</TD></TR></TABLE>
Good call, these are itr shocks, springs, and lca's..
Old Jul 3, 2005 | 04:43 PM
VTECisSeXY's Avatar
*insert here*
thanks you so much
dc2leftovers
Jul 24, 2009 12:27 PM
jplowman2005
Suspension & Brakes
Oct 9, 2008 04:05 PM
00siandrew
Sep 6, 2006 08:37 PM
I got a honda
Jan 8, 2005 10:10 AM
93delsol
Dec 29, 2002 10:34 AM
