B18 Piston question...
Old Jul 3, 2005 | 08:50 AM
ZedEx's Avatar
Default B18 Piston question...
I'm getting ready to do an LS swap into my 1994 Civic EX. I'm going to be using a B16 transmission and B18B block... However, the powertrain will be sitting in the shop for quite sometime, so I figure I may as well go ahead and do some internal work.
So I've been doing a bit of searching, and turned back a few things. It looks like B16 pistons would be the way to go... But what type? B16A, B16B? I'm not looking for an insane 13:1 compression ratio or anything. Somewhere from 11:1-12:1 would be great. Also, I haven't turned back anything on what Crankshaft is decent for this set-up.
Any suggestions?
Old Jul 3, 2005 | 08:56 AM
pdiggitydogg's Avatar
Type R pistons wont yield 12:1 on an ls block - you'll need forged aftermarket pistons to get that range. CTR in an ls block will be 11:1 tops
Thats with the ls crank, anyway
Old Jul 3, 2005 | 09:00 AM
Bense's Avatar
Default Re: B18 Piston question... (ZedEx)
http://www.c-speedracing.com/h...c.php
Old Jul 3, 2005 | 10:15 AM
Kyles ej1's Avatar
Default Re: B18 Piston question... (bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Type R pistons wont yield 12:1 on an ls block - you'll need forged aftermarket pistons to get that range. CTR in an ls block will be 11:1 tops
Thats with the ls crank, anyway</TD></TR></TABLE>
yea ctr pistons will give u the highest compression but only 11:1. u will need aftermarket ones if u want a higher compression
Old Jul 3, 2005 | 10:32 AM
ZedEx's Avatar
Appreciate the link Tum-Yeto. I've been looking for that page for a while.
So it's looking like with my B18B with P30 pistons, I should have a 11.3:1 CR. Granted, with OEM Headgasket, and no milling. Then once I swap the GSR Head on, that should bump me up to a 12.1:1 CR... Damn, this should be fun
Thanks again guys.
Modified by ZedEx at 11:44 AM 7/3/2005
gofastmobile
10
Sep 20, 2007 10:56 AM
b18bteg14
Jun 2, 2007 01:14 PM
92eg6lsvtec
Jul 22, 2005 12:11 PM
1BadDC2
Nov 30, 2003 07:18 PM
91civicDXdude
Jul 16, 2003 02:20 PM
