d15b7
Old Jul 3, 2005 | 08:34 AM
d16X's Avatar
Default d15b7
what car is this motor out of I came across one but wasent sure what car it came from
Old Jul 3, 2005 | 10:41 AM
theemaddhatterr's Avatar
92-95 civic dx basicly a same as a d15b2 with a d16a6 head and a little less agressive cam
Old Jul 4, 2005 | 07:17 AM
d16X's Avatar
ok thanks so do u think it would be worth rebuilding of just swap in a d16z6 and is the motor still obd-0
Old Jul 4, 2005 | 07:44 AM
d16X's Avatar
bump
Old Jul 5, 2005 | 12:56 PM
basicly a b7 is the 1.5 version of the a6(crx/civic si mtor) it does well with bolt ons and in a crx because of the weight it can be quick i had one for a while i was happy with it but it isn't obd0 but all you need to do is use a si/hf dizzy and si ecu the only problem i had was the thermal switch is on the water neck infront of the thermastate you need a converter for that but the guys at rywire.com can hook you up if you have rebuild it i wouldn't mess with it unless you don't have any other options
monkeykingscag
11
Feb 20, 2007 02:56 PM
91hob20hb
Feb 27, 2004 04:42 AM
projectcrx
10
Dec 4, 2002 09:09 AM
shoebox
10
Oct 29, 2002 07:38 AM
Rob!
Mar 17, 2002 06:27 PM
