new fuel filter..?
Old Jul 3, 2005 | 07:55 AM
crispvtec98's Avatar
Default new fuel filter..?
ok so im up in the 100+ category right now. i am wondering if it would be worth while to change my fuel filter and pump, or either or. i was wondering where the fuel filter is located, sorry if this is a re-post, and how hard it is to replace? same with the fuel pump. thanks alot.
Old Jul 3, 2005 | 07:59 AM
Dougs96SI's Avatar
Default Re: new fuel filter..? (crispvtec98)
There really is no point to replacing it. Pump should be replaced if it is failing and car is running very lean or you are boosting and need more flow.
Modified by Dougs96SI at 9:20 AM 7/3/2005
homesauce's Avatar
You should replace your fuel filter, it is located on the passenger side fire wall. Run a search , there are pics im sure.
Old Jul 3, 2005 | 08:00 AM
Dougs96SI's Avatar
Default Re: new fuel filter..? (homesauce)
what would the purpose of replacing it be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">You should replace your fuel filter, it is located on the passenger side fire wall. Run a search , there are pics im sure.</TD></TR></TABLE>
Old Jul 3, 2005 | 08:18 AM
vinuneuro's Avatar
Default Re: new fuel filter..? (Dougs96SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">what would the purpose of replacing it be?</TD></TR></TABLE>
What is the point of replacing your oil filter? Figure it out genius.
Old Jul 3, 2005 | 08:54 AM
maks's Avatar
I hit 100k km and I'm planning on changing my filter, although it's an optional thing, for those who have doubts... it's called preventive care... solving problems before they happen.
Here's the diagrams:
Hope that helps you find it!
Old Jul 3, 2005 | 11:48 PM
onefastrx7turbo's Avatar
Default Re: new fuel filter..? (CluelessDrac)
right. Basically it says to not worry about it until the fuel pressure drops below the minimum. I wouldnt change it unless you are having fuel press problems...
Neil
Old Jul 4, 2005 | 01:11 AM
xbn83's Avatar
I say just change it. It doesn't cost much and doesn't take long to do it. I changed mine at ~68k, guess what, the fuel came out of the filter was dark brown color (dirty). I changed it because I felt like to, not because something was wrong with my car. My car ran fine the whole time. I always used 93 octane. PREVENTIVE CARE my friend!
Old Jul 4, 2005 | 01:45 AM
bayareatuners's Avatar
replace it to be sure
Old Jul 4, 2005 | 02:09 AM
mkazm83's Avatar
Default Re: new fuel filter..? (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">PREVENTIVE CARE my friend! </TD></TR></TABLE>
I concur, but sometimes it turns into one of those "if its not broken dont fix it" kinda projects for some people.
Old Jul 4, 2005 | 06:21 AM
homesauce's Avatar
Default Re: new fuel filter..? (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
What is the point of replacing your oil filter? Figure it out genius. </TD></TR></TABLE>
HAHAHA pwnd
Old Jul 4, 2005 | 02:38 PM
H22a4u's Avatar
Old Jul 4, 2005 | 05:17 PM
98vtec's Avatar
moderator emeritus
Default Re: new fuel filter..? (H22a4u)
5th gens are a bitch to change
Old Jul 5, 2005 | 08:42 AM
5200BB6's Avatar
Default Re: new fuel filter..? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">5th gens are a bitch to change </TD></TR></TABLE>
very true, did mine my self...wow..almost had to give up and have a shop do it..but after a few hours (mostly trying to look up a site that tell how to do it in detail) i got it on and quess what?..it did not fix my problem (car was cutting off when i stop and car was ideling wrong) but atleast i know i have a clean one now..
Old Jul 5, 2005 | 01:51 PM
dannylee312's Avatar
Default Re: new fuel filter..? (5200BB6)
me too...if it wasn't for my friend to help me get out a piece of metal shaving in my threads, i probably would have been there until the night time. Thanks Duane. But when you change it, the fuel is much cleaner. I too am a very firm believer in PREVENTATIVE CARE.
Old Jul 5, 2005 | 03:20 PM
NormanBates's Avatar
Hi all, one part of the manual that was left out specifically says to replace the filter every 60,000 mi/96,000 km/48 mos (whichever comes first)...I kinda err on the side of everyone and the Honda engineers with this one.
ExVtec
Honda S2000
Feb 2, 2009 12:12 PM
keeblar
Jul 30, 2008 07:52 AM
aleks77
May 10, 2007 08:36 PM
the soL that could
Mar 12, 2006 09:20 PM
RedGSR
May 15, 2002 06:42 PM
