Which clutch to buy??
Old Jul 2, 2005 | 11:26 PM
AllAboutSleepers's Avatar
Default Which clutch to buy??
Hey guys, I've searched a bit and found mixed opinions. I'm thinking either ACT organic or Exedy organic for my 89 CRX si. Anyone have any experience based opinions?? thanks
Old Jul 2, 2005 | 11:34 PM
RCautoworks's Avatar
Default Re: Which clutch to buy?? (AllAboutSleepers)
ACT has never failed me yet and I have installed many on customer cars. I will always buy ACT. There is no reason not to.
Old Jul 2, 2005 | 11:36 PM
jc836's Avatar
The Exedy is an upgrade to the stock clutch. Unless you have a very high power or super grippy tires this should be just fine. We have an OEM unit in our race car and it works just fine on track. I would consider reliability of the drivetrain and your specific application before going to a high clamping rate. Iv'e been there with a muscle car and assure you that clutch life is different from stock (as is cost).
Old Jul 2, 2005 | 11:37 PM
Default Re: Which clutch to buy?? (jc836)
so your saying just to get an OEM because of the reliability or what?
Old Jul 2, 2005 | 11:49 PM
also, you said unless I have super grippy tires...I don't know if you would classify them as SUPER grippy but they are falken azenies
Old Jul 3, 2005 | 12:09 AM
Dancing is Forbidden's Avatar
Get an exedy Organic. That clutch can handle over 200whp.
Old Jul 3, 2005 | 12:29 AM
Bunger's Avatar
Default Re: Which clutch to buy?? (ih8jdm)
I would say Exedy also, good product.
Old Jul 3, 2005 | 12:34 AM
PINEAPPLE's Avatar
I have actually had both the act stage1 and currently exedy stage1.Both clutches perform very well. If you can get a deal on either one I would highly recomend them.
only thing that bothered me was the exedy clutch would chatter when moving slow in 1st. It seems to be a common problem but doesnt affect performance.
Old Jul 3, 2005 | 04:20 AM
88 rex's Avatar
Default Re: (PINEAPPLE)
OEM or equivalent.......make the clutch the weakest part of that whole driveline. You don't want a rock solid clutch that will tear your tranny apart.
*hint* trannies cost more than clutches and OEM will last quite awhile.
Upgrading the flywheel couldn't hurt though
Old Jul 3, 2005 | 07:12 AM
g2tegsown's Avatar
I have an exedy stage 1 clutch in my Integra and I love it, it grabs fast, but it still also allows for very streetable clutch. I do experience the same thing that PINEAPPLE mentioned. ("only thing that bothered me was the exedy clutch would chatter when moving slow in 1st. It seems to be a common problem but doesnt affect performance.") My car is kinda jerky with the clutch when I am in low gears (1st and 2nd) when I am not accelerating, but when I start to acclerate that thing grabs and I'm off
I would recommend the Exedy Clutch I also installed a lightend flywheel at the time which I also recommend
Old Jul 3, 2005 | 07:22 AM
yellowjdmcrx's Avatar
dude if i was u i would go ahead and change out the flywheel to a 90 crx and get a 90 crx clutch b/c it has a bigger clamp surface 200 for 89 compared to 212 for 90. that is what i am doin for mine.
oh and exedy all the way
Old Jul 3, 2005 | 07:59 AM
doubleA's Avatar
Default Re: Which clutch to buy?? (yellowjdmcrx)
If your NA either will work great. I had the exedy for a couple years and loved it. Untill I installed a big turbo and some falken azenies. Than it started slipping bad at full boost. Now im using a six pack sprung from clutch specialties.
hotimportcrx
11
Apr 8, 2023 07:33 AM
tsdneil
Apr 10, 2008 05:24 PM
GShizzR
Apr 21, 2006 11:53 PM
ThatRicerDaniel
Jan 15, 2004 08:57 PM
MechEng
Mar 29, 2003 10:36 AM
