Needed : BLOCK OFF plate for the Evaporator hole on the passenger side...
I took out my A/C from my crx.. Now there's a big hole on the passenger side where the evaporator lines where on the firewall.. Is there a part that I can buy to cover it ? If so, can you post the part # ? (I'm located in Canada)
here's a pic...
thanks in advance
here's a pic...
thanks in advance
i did that to and when i did it i used the same rubber groment but plug up the 2 hole in it with like gasket maker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknohatchie91 »</TD></TR><TR><TD CLASS="quote">just weld in a little plate and then paint it to make it look nice!
YOU CRAZY MAN ! I'll just buy the rubber grommet piece that was there...
</TD></TR></TABLE>YOU CRAZY MAN ! I'll just buy the rubber grommet piece that was there...
Sorry i cant help you with a part number, but i just picked up one from the junkyard from a non AC equiped car.
The one in the middle, the big black box. You either have to replace it with a duct from a non ac car or gut the stock one and use that.
it's not #12..that is just a grommet.. there is a metal peice that goes there..the grommet just covers the metal peice.. I tried using the grommet, but it keeps falling out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">it's not #12..that is just a grommet.. there is a metal peice that goes there..the grommet just covers the metal peice.. I tried using the grommet, but it keeps falling out. </TD></TR></TABLE>
I work in the parts department at Honda, and I don't recall seeing what you're referring to. I keep trying to find it in the parts catalog, so far I am unsuccessful. I am not at all saying you are wrong, but from my knowledge, that grommet should be all that is needed to block that hole.
I tried putting the grommet to cover the hole.. It wont stay !
if you look at this pic, you'll see metal peices...
take the Evap out..
its behind your glove box.. couple of 10mm bolts..
take it out..hallow it out ..and put the plastic shell back in..
Your are wrong. #12 is the correct piece I just bought one two months ago and its the correct part number.
Make a deal with your trade you the plug for your ac lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">take the Evap out..
take it out..hallow it out ..and put the plastic shell back in..</TD></TR></TABLE>
Exactly, this isnt that hard to do. After removal, the new grommet (from a non a/c equipped EF) will fit perfect.
I need that same piece. I have a hole right next to the fuel filter and can see directly into my passenger side wheel well. If I can't find something for under $5...i'm followin GreenMachine's advice.
