Ryan Basseri, are you out there? OBD0 to OBD1
I am doing a OBD1 D15B7 swap into my OBD0 '91 civic dx. I have both the B7 harness and the B2 harness. if i sent you both harnesses, could you build me the appropriate harness? could you get back to me on some options such as ECU conversion harness and dizzy plug adaptors? thanks.
Yes sir, if you send in both we can do that for you. You will need to buy the 0-1 ecu jumper as well. For your harness we will not use a distributor jumper or a vtec sub harness, we will simply add all the necessary wires to the dx harness, and make it look as stock as possible. The price is $300 and it will be a plug and play swap, no soldering needed.
Give us a call on the homepage number http://www.rywire.com
Ryan
Ryan
t-town_ep
Nov 19, 2012 12:54 AM
